Operating System Not Found
Discussion in 'General Software' started by keiwo, Jan 23, 2009.
  1. keiwo
    keiwo Geek Trainee
    Recently, i have been getting random blue screens and after the blue screen, it will say "Operating System Not Found". However after i hard shut it and turn back on, everything is normal again.
    The error report contains:
    C:\DOCUME~1\*****\LOCALS~1\Temp\WER20d4.dir00\Mini012309-02.dmp
    C:\DOCUME~1\*****\LOCALS~1\Temp\WER20d4.dir00\sysdata.xml
    Please can somebody give me a solution to the problem, the blue screens are happening more and more often.
  2. cube_
    cube_ Mega Geek
    It could be a multitude of problems... It could spawn from high temperatures, a faulty hard drive, RAM, a startup program...
    But for now, lets start out by cleaning up your system a bit.
    First, download these two programs:
    1. CCleaner
    2. Abexo Free Registry Cleaner
    Run them both and let them clean out all the junk your system has. Once they're finished, click start > run > type in "msconfig".
    Once the msconfig window has popped up go to the "startup" tab.
    Once in the startup tab, uncheck ALL and i mean ALL the programs you don't need.
    All you SHOULD need are protection programs (anti-virus, firewall...), and drivers (for your mouse, keyboard, graphics card...). Uncheck anything else like Itunes, Skype, Messenger...
    After following all these steps, your OS should function properly and more efficiently.
  3. jsbatalvi
    jsbatalvi Geek Trainee
    first of all blue screen error may be due to faulty ram. change and then check..
    secondly go to start>run type %temp% click ok . it will show temp directory of current user . delete all files from here. then restart computer. it will solve your problem
  4. cube_
    cube_ Mega Geek
    yes, it will
