Hi, i got PhotoShop CS2 installed, and i place some downloaded grunge brushes in the preset folder, go onto photoshop, and the brushes are not there, anyone know why? Thanks Will T
You don't add brushes like that you'll need to, download the brushes to say your desktop, then open Adobe Photoshop from here navigate to Edit > Preset Manager. This should be on the brushes "section", hit the load button, browse to desktop, select the brush file. You now have them loaded and ready to use!
