Please help, no power at all..
Discussion in 'General Hardware' started by eight420, Feb 11, 2008.
  1. eight420
    eight420 Geek Trainee
    My speaker fell on my computer and the computer shuts off....
    Go to restart and nothing, no fans, no hard drive, nothing.
    The NORMAL led light goes on for a half of a second goes off, then the first LED on the bottom stays on, manual says this LED is LED1 5VSB. Theres is also NO VSS light.
    I have nothing. But these lights are on so does it mean Its my motherboard?
    PLZ HELP
    __________________
    kn8-sli
    FSP group power supply
    AMD Athlon 64 2.2GHZ
    ATI x800 GTO 256MB
    1028MB Kingston DDR400
    80GB Western Gigital IDE
  2. Ashton
    Ashton Geek Trainee
    where on the pc did it hit?
    Check the inside of your pc for any visible damage.
    It could be one of the psu cable is broken or unplugged, try with another one. Make sure the 20/24 pin and the 4-pin are both plugged in and see what happens when you unplug the 4-pin and boot up.
