Dear all I have Intel d845gvsr motherboard with 256mb ram and the problem is when i switch on the system no display in monitor red led is flashing in front panel. I opened the cabinet and removed the ram and again i switch on it beeps 3 times with 2 sec time difference and it stops the beep itself, i cleared the cmos by removing the battery removing the jumper and the changed the working memory stick in slot but the same indication is repeating. When i remove the ram and switch on the system it start the power on self test (POST). First test goes to ram if the ram is not available it beeps for 3 times but if the ram is available it does not beep and does not boot. I cant understand whats the exact problem but i guess may be the onboard video card is failure but im not sure. Please let me know your ideas suggestion and is much appreciated. Many thanks in advance. Ranjith
Well, it definitely sounds like a memory issue. According to this page, it could be a few problems relating your memory stick. How many sticks do you have? If you only have 1 then try using a friends stick if possible. Ultimately, it has to be either a faulty memory stick or motherboard.
