Problem Adding anther SATA HDD to an existing SATA RAID - Please Help
Discussion in 'Storage Devices' started by saifbukhari, Jun 22, 2010.
  1. saifbukhari
    saifbukhari Geek Trainee
    Hi Folks,
    Im in a mess here, would appreciate your able advise on the same.
    The Issue:-
    I bought this via vt6421 pci sata card to plug in my extra HDD, And it didnt worked.
    The system boots to the card bios first and detects the extra HDD which i connected & there is a option for pressin <TAB> which doesnt work, after that when my existing configured Raid screen in Bios comes, it thinks for a while and throws up an error saying "there is some problem with your hardware" and sits there.
    My Configuration is:-
    CPU
    AMD Phenon II X2 550 BE
    Gigabyte GA MA790GP UD4H
    Memory 8GB 800 Mhz Dynet
    Graphics Card Saphire 1GB DDR5 ATI Radeon 5850
    Hard Drive 2x80GB IntelX-25M in RAID 0
    +1x320GB+1TB Seagate external HDD
    Power Supply: Corsair 750W HX
    Case : Cooler Master 690 II Advanced
    OS:Genuine Windows 7 Ultimate 64 Bit Retail Monitor
    Monitor: DELL ST2210
    I have six SATA IIports on my Mobo out of which:
    2 are occupied by the SSD's
    2 are occupied by the Top Panel of the Case for the Cooler masters X Dock (basically to attached a HDD externally
    1 is occupied by the DVDRW
    1 is occupied by the Card Reader
    Now I had this spare 1 TB HDD for which i bought this card but this problem came up.
    When i removed my extra HDD's sata cable and rebooted , at this point the machine booted fine, showing the Via Bios again but with no drives now as i unplugged the cable.
    My Queries Are:-
    > Since i have an onboard exisiting Raid configuration it might not work?
    > Does the Via Expansion Card doesnt support HDD capacity of more than 1 TB ( i just reaad some where)
    >Is it possible that atleast my DVD RW+Card Reader can be utilised via this Via Expansion card and in this way i could free up two sata ports on my Mobo for utilising my spare HDD's again?
    Please some one throw some light on this,would highly appreciate.
    Regards
    Saif
