Hi My operating system was crashed last week and I tried to install fresh copy of windows XP. Although I set the CD Drive in my laptop as first in booting order, the laptop does not boot from CD Rom. I could not install any OS. Could you please give me an idea to solve the issue? Note: 1. I have made sure that there is no problem with CD-Drive or installation CD. 2. I have enough experience with installing OS in normal situation. So, I am looking for more technical solusion (I reckon there may be a problem in CMOS). Thanks Thilee
Search for the software : " MHDD " in google , download the software and burn it up on a CD then run your computer from the CD ( just like you're trying to installing a new system operation ) the software will start automaticlly , then the software will give a number to your HDD , press the number you see beside your HDD then you'll be able to FORMAT your HDD drive by writing the command : CLRMBR ... it will FORMAT your HDD in a second ... Wish you good luck ...
What kind of drive do you have ? Is it a DVD rom or Combo drive ? What is the make of the laptop ??? How old is this laptop..
