Problem with SAMSUNG Spinpoint F3 HD502HJ
Discussion in 'Storage Devices' started by 1233445566, Jul 4, 2010.
  1. 1233445566
    1233445566 Geek Trainee
    Hi
    I have bought this hard disk about 1 week ago, and since then I have 2 problems.
    1. I have received this error for several times:
    More details in the event viewer:
    Windows Disk Diagnostic detected a S.M.A.R.T. fault on disk SAMSUNG HD502HJ ATA Device (volumes C:\;D:\;E:\). This disk might fail; back up your computer now. All data on the hard disk, including files, documents, pictures, programs, and settings might be lost if your hard disk fails. To determine if the hard disk needs to be repaired or replaced, contact the manufacturer of your computer. If you can't back up (for example, you have no CDs or other backup media), you should shut down your computer and restart when you have backup media available. In the meantime, do not save any critical files to this disk.
    2. For several times, at windows, suddenly the picture got noisy and the sound hanged up(like cd's scratch), and 1 second after, this blue screen showed up:
    http://www.imagedoll.com/out.php/i1461_30062010.jpg
    I've re-installed the windows, changed the PSU in use, but none of them worked.
    The problem is here that every diagnostic software I used, has never detected any problem. HD Tune Pro, Speedfan, HDDLife and even ES Tool (which is Samsung's diagnostic utility) says my hard disk is healthy and no problem was found.
    How can I diagnose if this is from hard disk or not?
    Any help is strongly appreciated!
  2. daz
    daz Geek
    did you try to do error check by windows before it starts up?
