right, having a problem with SW & YT, konqueror advised me about a new version of flash, however, i've DLd flash-plugin-9.0.124.0-release.i386.rpm & converted it to a deb, but, everytime i try to install it with adept, konsole of whatever database locked / already in use, adept output is here Code: (no debugging symbols found) Using host libthread_db library "/lib/tls/i686/cmov/libthread_db.so.1". (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) [Thread debugging using libthread_db enabled] [New Thread -1235433792 (LWP 4419)] (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) [KCrash handler] #6 0xb7fa0410 in __kernel_vsyscall () #7 0xb6627875 in raise () from /lib/tls/i686/cmov/libc.so.6 #8 0xb6629201 in abort () from /lib/tls/i686/cmov/libc.so.6 #9 0xb68336e0 in __gnu_cxx::__verbose_terminate_handler () from /usr/lib/libstdc++.so.6 #10 0xb6830f65 in ?? () from /usr/lib/libstdc++.so.6 #11 0xb6830fa2 in std::terminate () from /usr/lib/libstdc++.so.6 #12 0xb68310ca in __cxa_throw () from /usr/lib/libstdc++.so.6 #13 0x0812b916 in ?? () #14 0x0812be8a in ?? () #15 0x0812bee8 in ?? () #16 0x0812c735 in ?? () #17 0x0812a22d in ?? () #18 0x08114379 in ?? () #19 0x080951ed in ?? () #20 0x0807378d in ?? () #21 0x0807408e in ?? () #22 0xb6e77893 in QObject::activate_signal () from /usr/lib/libqt-mt.so.3 #23 0xb72038ec in QSignal::signal () from /usr/lib/libqt-mt.so.3 #24 0xb6e97842 in QSignal::activate () from /usr/lib/libqt-mt.so.3 #25 0xb6e9f258 in QSingleShotTimer::event () from /usr/lib/libqt-mt.so.3 #26 0xb6e0eaf0 in QApplication::internalNotify () from /usr/lib/libqt-mt.so.3 #27 0xb6e1091f in QApplication::notify () from /usr/lib/libqt-mt.so.3 #28 0xb75d4cd2 in KApplication::notify () from /usr/lib/libkdecore.so.4 #29 0xb6da1209 in QApplication::sendEvent () from /usr/lib/libqt-mt.so.3 #30 0xb6e0153b in QEventLoop::activateTimers () from /usr/lib/libqt-mt.so.3 #31 0xb6db5d49 in QEventLoop::processEvents () from /usr/lib/libqt-mt.so.3 #32 0xb6e291ce in QEventLoop::enterLoop () from /usr/lib/libqt-mt.so.3 #33 0xb6e28fde in QEventLoop::exec () from /usr/lib/libqt-mt.so.3 #34 0xb6e10699 in QApplication::exec () from /usr/lib/libqt-mt.so.3 #35 0x0806f75e in ?? () #36 0xb6613050 in __libc_start_main () from /lib/tls/i686/cmov/libc.so.6 #37 0x0806f401 in ?? () YT was loading unformatted HTML but now it go straight to OpenDNS BTW: rebooted a few times & no managment SW in ksysguard, very if i need to update flash, how can i with database locked
found the prob YT is now down, so, something must have being wrong before hope it not down for long Edit: failing servers: dns1.sjl.youtube.com & dns2.sjl.youtube.com Edit: now i've learned that YT has moved to a new domain "youtubeonline.com" , so, i'll just wait until they sort it :doh:
Holy crap, DNS hijacking! YouTube.com is still YouTube.com, Google would be nuts to change it. However, a quick whois of youtubeonline.com reveals the following: ...sounds legitimate, no? :dry: Which DNS server(s) are you using in your router man? It sounds like they're poisoned.
In future, please don't use SW and TY without telling us what they mean. They're not standard abbreviations, so there's no way to be sure. Surprise surprise, in Cairo . Youtube.com works fine for me.
Whoops, I missed that line the first time. OpenDNS can be a bit sketchy, and it's very non-standard in the way it handles DNS. I actually had a drawn-out debate about it with OpenDNS' CEO a while back: RoadRunner Intercepting Domain Typos ...As I told him, pure DNS is the way to go. I don't want anybody tampering with my forward lookups! The other big downside you've already experienced: OpenDNS is a big target for local DNS poisoning attacks.
ok, no probs, sorry[ot]Addis slaps the back of donkeys legs, & donkey likes it, but he instantly realizes he's in trouble so he stops smiling[/ot] so, is using OpenDNS a good idea, or can you recommend a better free DNS ? BTW: you seem to be saying their not good here BTW: after a lot of p1ssing about everything seems fine with youtube now, i'm unsure if tinkering fixed it or just time, but i suspect it was time as all i really did basically was reinstall my browser, obviously other stuff to but nothing i think would cause that, except my / partition was full
