Problems with mobo (i think)
Discussion in 'CPU, Motherboards and Memory' started by Mosqwik, Sep 25, 2007.
  1. Mosqwik
    Mosqwik Geek Trainee
    So i have a ASUS P5VDC-X mobo which worked great. Then i decided to clean the parts, removing dust and such so i removed all the parts and when i put them back the computer wont start. When i try to turn it on it gets power (the CPU and PSU fans start spinning) but then instantly turns off (fans stop spinning).
    I tried plugging in the PSU in another computer and it works fine, as does the CPU so those are fine. The RAMs are ok aswell so i came to the conclusion that the mobo is at fault. I can not figure out what it is. The only clue i have is that fter i had cleaned it and put back all th parts i had a Jumper left over but after hours of trying different stuff it doesnt work so i figured it was nothing important.
    Does anyone have an idea of what may be wrong or is the mobo damaged because of static electricity? (Note that i didnt use any protection against the latter because i havent had to before).
    Thanks in advance.
    EDIT: I read some other guys thread (the "no power" thread) and i basically have the same problem but i dont have a case, actually i havent used a case for maybe one year with this computer and it still has worked fine until now.
    How do check if the mobo is fried?
  2. Big B
    When you disassembled the system, did you clean off the thermal material from the CPU and heatsink with isopropyl alcohol and then reapply a paper-thin layer of thermal paste or a new pad? If not, that's where I'd start.
    Next, make sure any and all power connectors on the motherboard are plugged in. If your video card has a power connector on it, make sure that is plugged in as well.
