quiet fan
Discussion in 'Overclocking & Cooling' started by hausnfranz, Dec 9, 2007.
  1. hausnfranz
    hausnfranz Geek Trainee
    Hello all,
    I am looking for a quiet fan, as the one I have is really really loud. I have included system specs and pics to help. Can anyone provide me with a suggestion?
    Property Value
    Manufacturer Intel
    Model SE7525RP2
    Version C96126-450
    Serial Number QSRP64400205
    Chipset Vendor Intel Corporation
    Chipset Model 525 Workstation Memory Controller Hub (C4-step)
    South Bridge 6300ESB LPC Inteface Controller
    SMBus Intel Corporation 6300ESB SMBus Controller @0400h
    CPU Intel Xeon
    Cpu Socket Socket 604 [CPU 1]
    Processor Upgrade ZIF Socket
    Max CPU Speed 2800 MHz
    System Slots 4 PCI
    OnBoard devices
    Video (Enabled) ATI Rage XL
    Ethernet (Enabled) Marvell 88E8050
    Memory Summary
    Location System board or motherboard
    Maximum Capacity 8192 MBytes
    Memory Slots 4
    Error Correction Single-bit ECC
    Use System memory
    http://i275.photobucket.com/albums/jj317/hausnfranz/IMG00085.jpg
    http://i275.photobucket.com/albums/jj317/hausnfranz/IMG00084.jpg
  2. thomasbuonoman
    thomasbuonoman Geek Trainee
  3. hausnfranz
    oops, the large fan in the back isn't plugged in actually.
    Its the lil small one that sounds like a hair dryer.
    thanks for the reply too.
  4. Ghostman 1
    Ghostman 1 Mega Geek
    Thats your processor fan and heat sink, I would just order a new heat sink an fan..
  5. gazaway
    gazaway Geek Trainee
    You aren't going to get too much of a selection for a socket 604. The fans are smaller (60 - 70mm) so either way they are going to be kinda loud. This is the best I could find for you in under 5 mins though:
    Newegg.com - Dynatron H6HG 60mm 2 Ball CPU Cooler - Retail
    It's got a copper heatsink and a 2 ball bearing 60mm fan..
  6. hausnfranz
    Why are there so few choices? I see tower pcs all the time that are quiet, I wonder if its just the xeon?
  7. hausnfranz
  8. gazaway
    That would definately work if you can fit it in your case. Just remember that the thing is huge... and aluminum.. The 120mm fan would be nice and quiet. The reason why your choices will be limited is because socket 604 isnt exactly a widely used socket. Most consumers use 775 or AM2 now a days so that is what is easiest to get.
