Hi I have just purchased a ATI Radeon HD5670 GPU. Im having a problem with my new GPU, it fails to display anything when I boot up my machine. As far as I can see my machine meets the requirements for the GPU. minimum 400W power PCI Express X16 slot minimum 1Gb system memory My Pc Spec is as follows: Mobo: DFI Lanparty UT RDX200 CPU: AMD Athlon 64 X2 Dual Core 4600+ 2.4Ghz Ram: 2GB (2x 1GB DDR333) Working GPU: Nvidia GeForce 7600GT PSU: Antec Neo HE (550W) Any one got any ideas Regards Andy
I would put the card in another computer to see if it's ok first. The PSU should be sufficient, otherwise it would cause other kind of misbehavior.
