hello when i was cleaning my pc i removed my ram when i put it back on my motherboard and started the pc but it did not start after start i get amd 3 beep error ( problem whit the ram ) ram is thested on other pc and its working what to do ?
i try it i put out battery for like 1h then i re inserted the ram and it did not work ;/ if you need more info tell me
So your ram is PC-3200 ?or pc-2700 ? And it works in another computer? Test your ram 1 stick at a time in different slots... then try different ram in those slots. That is an old board, maybe the ram slots burned out..
PC is 3200 i did all this i tested the ram on other pc and its working i just plug it in then i cleaned whit cotton then i put it back in is it posible to burn this easy ?
Oh yea! It doesn't take much ...I would try another ram, PC-2700 or PC-2100.. Test with 1 stick.. Sometimes the pc-3200 sticks don't work so good in the older PC's I have a Older MSI board that takes all three different size of ram, But will only run on the pc-2700 ...
Yea! That Motherboard supports a bunch of different Memory chips.. Like these.. ASRock G PRO takes the PC1600/2100/2700 DDR SDRAM DIMMs or PC100/133 SDRAM DIMMs Memory Type. I would use pc-2100 DDR 184 pin -266 mhz... Thats what it say to use(default) Can you read the chip you have and tell me what it says ?
i will read it tomorrow im at work now i think i will bar SDR ram and try will it work do you think its a good idia ?
That is a real old Motherboard if it will also take PC-100/PC-133... Not sure what you mean..Bar SDR ??
yes i find a SDram 512 mb 133 i think if my DDR ram is broken and it cont be used i can use the SDRam slots for ram motherboard have 2 DDR and 2 SDR slots soo if the one dont work i can try the other or you think its not very good idia ?
Yea! I would try it.. The Pc-133 would be better than PC-100.. That is an old ball Motherboard.. But what ever works..
WISEKICKER: You really should Start your Own post and not hi-jack someones else post...Please start your OWN POST..
