Hi, I would like help with something, I have a Dell Studio XPS 1645 laptop its running: Intel i7-720QM running @ 1.6GHz (Specifications can be found here ). Its about 2 year old now so I decided to upgrade the RAM in my laptop to 8GB DDR3 Crosair Vengeance RAM running @ 1600MHz (Specifications can be found here ), however, when I check the bios it registers the 8GB ram but it says its only running at 1333MHz? I heard that it can only run as fast as the CPU can handle is that correct? Or do I need to change some settings? Thanks for your help! Regards,John
The speed you are mentioning is the bus speed frequency, not the CPU frequency. The Intel i-series no not have a memory controller, so it depends on the maximum memory speed of your motherboard.
