I just got a this computer: i5 on MSI H61M-P31/W8 Motherboard and 4GB DDR3 Memory. Decided to add 8GB PC3 10600 IBM SDRAM and it still only sees 4GB. I swapped modules but nothing changes. Im running on windows 7 64bit if i remove old 4GB and start on new 8GB it doesnt start at all. Keep rebooting and i cant get into setup. Now my question: is the new 8GB module faulty or is there something i do wrong? Thanks
Are All the Ram sticks the same ? (PC310600) You Might have to reset the Bio's, Pull the Bio's battery out for 10 minutes, then replace and see if it picks up all 8 gigs of ram.
quote from motherboard manual after checking, is any chance of EMI locally, if so change Spread Spectrum to reduce EMI check those & what BIOS are you running ? presumably 3.5
