Random: Art with nmap and etherape
Discussion in 'General Chat' started by Impotence, Nov 30, 2006.
  1. Impotence
    yeah, its 5:30am so i have nothing better to do than anything which avoids sleep!
    Code:
    sudo apt-get update && sudo apt-get install nmap etherape && gksudo etherape
    This will install nmap and install and run etherape, click Pref. and turn off name resolution in etherape
    and in another terminal...
    Code:
    nmap -sP -iR 150 -n
    now keep your eye on etherape, 150 nodes will appear and patterns start to form on the lines representing the connections...
    note: "nmap -sP -iR 150" instructs nmap to ping 150 random IPs, if you'd rather not be spewing echo requests across the Internet then use "nmap -n -sP 192.168.255.*"
    The more nodes you ping the more impressive it becomes...
    if your really bored turn on dns resolution (nmap -sP -iR 150 -R) and watch all the dns replies come back in wireshark for the next few minutes after you kill nmap...
  2. megamaced
    megamaced Geek Geek Geek!
