Re: Best CPU Cooler
Discussion in 'Overclocking & Cooling' started by Dambuster, Feb 25, 2007.
  1. Dambuster
    Dambuster Magic
    Best CPU Cooler
    Is the ASUS Silent Square Pro any good for the Intel Core 2 Quad? If one considered overclocking... what about the ASUS Silent Knight ? BTW sorry Big B... I just didn't think about it:O
  2. Big B
    Asus Silent Square Pro
    You can start a new thread...
  3. Swansen
    Swansen The Ninj
    Best CPU Cooler
    i did a lot of looking around and theses are the ones i found to be the best
    titan Vanessa (L-Type)
    Sonic Tower by Thermaltake
    Thermalright Ultra-12
    thermalright sonic tower rev2 CL-P0323
  4. Big B
    Best CPU Cooler
    How much are you looking to spend? Do you want to stick with air, or are you considering liquid cooling?
    Also, my dad just upgraded his upstairs box to C2D, and the stock fan is really quiet. You might just check that out first and see how that suits your tastes. C2D runs pretty cool as it is, so if you're not looking for heavy overclocking, I'd give the stock cooler a whirl.
  5. Dambuster
    Dambuster Magic
    Best CPU Cooler
    Yeah, you're right, I'll check the Quad's stock cooler then see... I'm looking for the most efficient air cooling in case the stock cooler isn't enough or is too noisy. Price isn't a problem at this stage. Just 2 things: 1. silence, 2. Efficiency.
