Right to left
Discussion in 'Windows OS's' started by Peterkins, Feb 9, 2008.
  1. Peterkins
    Peterkins Geek Trainee
    Hi everyone, I am running windows XP home the default language is English and second language is Hebrew, my problem is I can't get Hebrew to run right to left in outlook express or in the google bar. The Hebrew letters go from left to right and I can't work out how to get it going the other way. It works fine in Open Office but that's about all any help would be very gratefully received. Peter
  2. Peterkins
    Hi, Have I baffled all those great minds out there or do you need more information? Peter
  3. edijs
    edijs Programmer
    in OE - don't the standart formatting options work?
    in Google toolbar - if you mean the search bar, then I'mm not so sure - I think that the alignment is pre-set in the code, although, I'd suggest you mail them for this. :rolleyes:
  4. Peterkins
    Hi, Tried all the formatting options all I get is hebrew going from left to right even when I click right to left document, I'm a little computer challenged so maybe I'm doing something wrong. Many thanks for the reply Edijs. Peter
