Hi all. So I finally bought my 22' Samsung and although it came with the infamous A panels I hooked it up. After reading about 150 reviews on Newegg I was pretty sure this was the right screen - all saying this is the best 22' out there. First thing I noticed was that the colours were WAYY of from factory. ("upgrading" from a ViewSonic so) Anyho adjusted the colours but still have a huge problem with black and white; The just look so awfull on this screen! Was playing Oblivion which was impossible because in dark areas everything just turned into one big grey cloud. I also gave up watching Last Exile after that oh so pretty milky sky on my CRT turned into 22 inches of pure indistinguishable whiteness on my Samsung. I don't know if theres something wrong with my screen or neweggs reviewers eyes? So: Is it common for LCD's (TN panels) to display light and dark colours so poorly? Is there some sort of adjustment trick that make it all go away? Or should I return and get an S version instead of my A? OR - return and save up for a Dell 2407?
