I have a GeForce 7300 GS in my PC and the VDO tool tells me that it is SLI capable and just says add another graphics card for improved rendering. As it happens, I have another GeForce 7300 GS so would I be able to just stick it in there? Sorry if this seems really basic but I didn't even know SLI existed until a couple of days ago so I'm not too hot on the subject.
if the card supports sli, which i think all 7 series cards do and as long as you have the hardware bridge then you should be good. Oh wait they need to be same hardware manufacturer as well. Also i am guessing that they are PCI-e and you have 2 PCI-e slots
While it does do SLI, it doesn't need the bridge...which is good given there's no connector for the SLI bridge.
