as you can see from the images my kaffeine installed kaffeine copied from help on the menu's, my kaffeine doesn't have DVB and a stupid error message keeps popping up every time i start kaffeine i know this is my fault, i did alter something in the DVB menu, then the error appeared, although kaffeine works clicking the error is bl**dy annoying, when i know i dont need to, so how do i make DVB reappear ?[ot]looked all over kaffeine, but cant find it[/ot]
Do you have a TV card then? The DVB menu will only appear if you have a capture card such as a Hauppauge Nova-T I *think* what you've done is enabled the Kaffeine DVB client without a TV card. The TV client is for broadcasting the TV over the network. Go to Settings > Configure Kaffeine Player > DVB Client > Uncheck 'Enable DVB client'.
