Hey, I've recently installed a sound card in my girlfriends computer (soundcard from ebay) and the computer now wont shut down. I'm guessing this is a hardware fault, but figured I'd check here first. What action should I take if it is a hardware fault? Thanks
First, Try it in all other slots, Then try another sound card , Or try that sound card in another computer..
Ya, its better to check the sound card on a separate slot and on another machine. How did you shutdown the machine, using power button or follows the Log Off option to end the session?
