Sound problem on mic
Discussion in 'Sound Cards and Speakers' started by mat58, Oct 26, 2006.
  1. mat58
    mat58 Geek Trainee
    I have this sound problem when i use the mic on msn or skype that you have to have your mouth right on the mouth piece to be heard. If you move away slightly the other person cannot hear you only background noise. I think i have it set up ok as followed skpe instructions and i have tried it with two different makes of mic with the same results. any ideas?
    Many thanks in advance
    Mat58
  2. donkey42
    donkey42 plank
    is the volume turned up on the mic channel ?
  3. Addis
    Addis The King
    Go to the volume control, enable advanced controls in options (i think thats it) and then enable "mic boost".
  4. mat58
    mat58 Geek Trainee
    Have tried all the volume settings and mic boosts and even tried the hardware test but not getting anything!
  5. Karanislove
    Make sure that pin is plugged in properly... I mean press little bit hard when u insert it....
  6. mat58
    mat58 Geek Trainee
    Pins in hard still mouth needs to be on the mic to be heard.
