SSH problem
Discussion in 'Networking and Computer Security' started by megamaced, Jan 16, 2007.
  1. megamaced
    megamaced Geek Geek Geek!
    I can't seem to connect to my Kubuntu 6.06 computer via SSH. I've configured my laptop (Xubuntu 6.10) and my other desktop (Ubuntu 6.10) with SSH and they can both connect to each other. I can connect to the * 6.10 computers using my Kubuntu desktop. From my Xubuntu machine I get the error:
    Code:
    "ssh_exchange_identification: Connection closed by remote host"
    Any ideas? :)
    EDIT: Just thought I'd say the Kubuntu machine is not running a firewall.
  2. Impotence
    try ssh in verbose mode [ ssh -v user@host ] ... might give a few clues as to where its failing!
    random post/s ive found that might help
  3. megamaced
    This is the output:
    Code:
    OpenSSH_4.3p2 Debian-5ubuntu1, OpenSSL 0.9.8b 04 May 2006
    debug1: Reading configuration data /etc/ssh/ssh_config
    debug1: Applying options for *
    debug1: Connecting to 192.168.3.61 [192.168.3.61] port 22.
    debug1: Connection established.
    debug1: identity file /home/david/.ssh/identity type -1
    debug1: identity file /home/david/.ssh/id_rsa type -1
    debug1: identity file /home/david/.ssh/id_dsa type -1
    Any clues?
  4. Impotence
    Code:
    ubuntu@ubuntu:~$ ssh -v ubuntu@localhost
    debug1: Connecting to localhost [127.0.0.1] port 22.
    debug1: identity file /home/ubuntu/.ssh/identity type -1
    debug1: identity file /home/ubuntu/.ssh/id_rsa type -1
    debug1: identity file /home/ubuntu/.ssh/id_dsa type -1
    [B]debug1: Remote protocol version 2.0, remote software version OpenSSH_4.3p2 Debian-5ubuntu1[/B]
    debug1: match: OpenSSH_4.3p2 Debian-5ubuntu1 pat OpenSSH*
    debug1: Enabling compatibility mode for protocol 2.0
    debug1: Local version string SSH-2.0-OpenSSH_4.3p2 Debian-5ubuntu1
    debug1: SSH2_MSG_KEXINIT sent
    debug1: SSH2_MSG_KEXINIT received
    debug1: kex: server->client aes128-cbc hmac-md5 none
    debug1: kex: client->server aes128-cbc hmac-md5 none
    debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
    debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
    debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
    debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
    debug1: Host 'localhost' is known and matches the RSA host key.
    debug1: Found key in /home/ubuntu/.ssh/known_hosts:1
    debug1: ssh_rsa_verify: signature correct
    debug1: SSH2_MSG_NEWKEYS sent
    debug1: expecting SSH2_MSG_NEWKEYS
    debug1: SSH2_MSG_NEWKEYS received
    debug1: SSH2_MSG_SERVICE_REQUEST sent
    debug1: SSH2_MSG_SERVICE_ACCEPT received
    debug1: Authentications that can continue: publickey,password
    debug1: Next authentication method: publickey
    debug1: Trying private key: /home/ubuntu/.ssh/identity
    debug1: Trying private key: /home/ubuntu/.ssh/id_rsa
    debug1: Trying private key: /home/ubuntu/.ssh/id_dsa
    debug1: Next authentication method: password
    ubuntu@localhost's password:
    The line in bold is where the differences start... the remote client is the one that kicking you, and its something to do with a version check...
    try the following, and see if you get the same as i did. (only instead of telneting into into your local box, telnet into the remote box)
    Code:
    ubuntu@ubuntu:~$ telnet 127.0.0.1 22
    Trying 127.0.0.1...
    Connected to 127.0.0.1.
    Escape character is '^]'.
    what does the remote ssh server report itself as?
    [OT]
    FYI: Im currently running from a Ubuntu LiveCD
    [/OT]
  5. megamaced
    I've sorted it!
    A bit of Googling suggested I look in the hosts.deny file. I remembered that I set my Kubuntu machine's host.deny file to read 'ALL: ALL', whereas my other computers read 'ALL: PARANOID'. So I made the changes to the Kubuntu box and all is well now.
    Thanks for your help
  6. Impotence
    no problem, i saw the same advice to check the hosts.x files, but for some reason i didn't even consider the idea that you'd played with them! sorry :/
    don't forget the solved button
