Hello, and thanks in advance for any help you might provide. I have a Toshiba Satellite laptop and a Trel 650 PDA / phone. I downloaded some (Monty Python) sound clips and tried to install them to my phone. I got a weird noise instead of one of the clips, so I deleted the file. Now on my computer I have the same noise coming out of my speakers all the time. I've looked for the old files on my Palm and on my computer but I can't find them, and I don't know enough about the audo setup to know how to find the stinkin' files and get rid of them!! The noise sounds like an electrical whoomb whoomb, then an electronic click! I know this isn't much of a technical description, but it's the best I can do... this is a bit over my head in the technical areas. Thanks!!
If you can remember the names of the files try doing a windows search for them. Try running your virus software too... you never know!
