strange hardware entry
Discussion in 'Windows OS's' started by etrich, Mar 4, 2006.
  1. etrich
    etrich Geek Trainee
    howdy folks, I have just re-installed XP after 2 years of virtually troublefree use.
    All seemed fine until I opened up 'My Computer',I had an extre (scsi) dvd drive.
    ON checking my hardware list I found an entry for SCSI and RAID controllers,despite not having any such hardware.
    With systen restore turned OFF I deleted both entries (dvd rom and scsi controller) from the list, but each time I Boot up they have returned!!!!:confused:
    Can anyone enlighten me as to what the hell is going on??
    Many thanks
    eddie
    Hardware= MSI M/B,Athlon,640megs memory,nvidia graphics,cd rom,cdrw,Belkin NIC,generic usb card,80gig HD
  2. Addis
    Addis The King
    Do you have any drive emulation software running like Daemon Tools, or Nero something which could be making a virtual drive for you to load disc images? Usually that type of software makes the PC think that theres a SCSI drive.
  3. etrich
    etrich Geek Trainee
    No, Other than Nero burning rom software.
  4. StimpE
    StimpE lol, Internet!
    Open up device manager, find the selected scsi devices/hardware, right click and disable. It's probably drive emulation software you installed like Alcohol 120%, etc.
