system file not suitable for running ms-dos or windows applications HELP!!
Discussion in 'General Software' started by vinylmason, Feb 11, 2005.
  1. vinylmason
    vinylmason Geek Trainee
    this is the error i get when trying to install a few things that were already on this same computer, C:\windows\system32\autoexec.nt. the system file is not suitable for running ms-dos and microsoft windows applications.can any body help
  2. Nic
    Nic Sleepy Head
    I had this problem a while back I think I fixed it by opening notepad and saving a blank page as autoexec.nt and copying it to C:\windows\system32. Let me know if this works because there may have been other steps that I have forgotten.
  3. vinylmason
    Tryed it didnt work,anymore ideas?
  4. Nic
    Nic Sleepy Head
    yep try putting your windows cd in
    Go to start + run + type cmd
    type in
    expand CD-ROM Drive Letter:\i386\config.nt_ c:\windows\system32\config.nt
    expand CD-ROM Drive Letter:\i386\autoexec.nt_ c:\windows\system32\autoexec.nt
    expand CD-ROM Drive Letter:\i386\command.co_ c:\windows\system32\command.com
    exit
    EDIT: I do have some more steps if that doesnt work but I think that should.
    Tell me if it works
  5. vinylmason
    you kinda lost me on that one?expand cd-rom drive letter.do i write that in that way or put the drive letter in F:\? cornfused :confused: :confused:
  6. Nic
    Nic Sleepy Head
    just type that in command
    eg where it says expand CD-ROM Drive Letter:\
    i would put expand E:\
  7. Addis
    Addis The King
    Yes you substitute that for your CD drive letter.
  8. vinylmason
    THANK YOU !!! very much it worked,thank you thank you thank you
  9. Nic
    Nic Sleepy Head
    No probs mate
  10. vinylmason
    Well I thought it worked,it did let me load my cd burning software but the program does not reconize my cd drives now,and I still cant load my games.did the comands you gave me have to be entered in the order you gave them to me?because i put the first one in wrong and re entered it last?
  11. Addis
    Addis The King
    I don't think that it matters which order you do them.
  12. Nic
    Nic Sleepy Head
    I'm not sure i've never entered them in the wrong order but I would assume that shouldn't be a problem. Your cd burning software sounds like its a problem with drivers or with the actual prgram but im not sure about the games
  13. vinylmason
    I just added an 80 gig external hd,have been moving stuff to it ,could that be the problem,maby i moved somthing i shouldnt have?Oh well thanks again for all your help,
  14. vinylmason
    anymore ideas???still getting the same error
  15. mikepickard
    mikepickard Geek Trainee
  16. vinylmason
    Thanks everybody,Reloaded windows,that fixed everything.
