System freeze
Discussion in 'CPU, Motherboards and Memory' started by devilboy, Aug 14, 2007.
  1. devilboy
    devilboy Geek Trainee
    Please give your suggestions ..
    I have got dual OS Suse Linux and XP installed in Pentium IV 2.4 GHz machine ...RAM - 512 MB HDD - 80 GB No Graphics Card
    My system freezes after I log in, in about 10 or 15 minutes.Thought that this may be an XP problem and tried Linux...The problem persisted ....Decided that its a hardware related issue ....
    If I allow it to cool for some 4 hrs it works again for some 2 hrs ...I have been using the system for 2 years now ...had few overheating problems ...would then clean the system and it will go smooth...
    When I googled for system freeze I get several articles related to HDD failure ...am confused :(
    Now how should I proceed ...
  2. Dracos
    Dracos Geek
    firstly welcome to hwf
    it may be a overheating problem beacuse you say you worked for two hours after giving a break
    otherwise the heating problem may have penetrated the hdd if you are sure that the hdd is damaged
    but i think before anything, you should try to format the hdd it may be a booting problem as linux may have been damaged and xp is starting from linux while booting so a format will do it may be if you cannot format hdd try low level formatting but this will damage hdd a little bit anyway it will be better than buying a new one
    another case is the thermal paste on cpu may have spilt around check it too beacuse it is the most case of thermal problems
  3. devilboy
    Thanks Dracos
    Instead of formatting HDD is it possible to check for errors ...Can you name some software that will do this
    This is it ...I think this should be the reason ... But I dont know how to check this split up nor where to look for it ...Can you please guide
  4. Dracos
    Dracos Geek
    gotta remove the cooler out from the cpu and check for the loss of paste on the coolers copper back and your cpu, they'll catch your attention immediately
    well there is not that kind of software but some tuners can help maybe to keep registry keys stable
    check CCleaner - Home but i don't think that it will work
    also when you remove the cooler (i think it's the stock intel one) remove the fan bridge on the Al blocks and clean the dust between them with an elect. sweeper
