Hello, I have problem with Thunderbird, here it goes: Example: Server1: outgoing: example1.smtp.com ingoing: example1.smtp.com Server2: outgoing: example2.smtp.com ingoing: example2.smtp.com Outgoing example1.smtp.com is set to primary outgoing server on both accounts. But whenever I reply to some mail in server2 (or compose a new one), Thunderbird wants to send a new mail using example2.smtp.com I want Thunderbird to use only example1.smtp.com - ALWAYS, but can't manage to get it. Thanks in advance.
Shouldn't be : incoming: pop.example1.com outgoing :smtp.example1.com Don't you have use pop. or pop3. for all incoming?
well it's actually mail.domain.si for outgoing and ingoing, but since my ISP blocks outgoing port 25, I want to use smtp.gmail.com (uses port 465) but whenever I reply to some e-mail (or compose a new one), Thunderbird wants to send the e-mail over mail.domain.si. And yes, smtp.gmail.com is set as a primary outgoing SMTP server.. I hope you understand my problem, otherwise I'll try to explain in a different way. By the way, mozilla doesn't have an official forum, do they ?
You can check here: Index - SillyDog701 Message Centre click on the Firefox/Seamonkey/Netscape under browsers.. They have Thunderbird there.. You can post a Question there.. They are real good there.
