you know when you have the sorce too loud and the primary volume low you get that heavy distortion effect (you sometimes get them on ameture pirate video's) well when i play mp3s or videos i get this effect, it is totally distorted all i can say is there's a fault somewhere along the lines. ALL volume controls are set to low, my audio equiliser is also low and my 'recording' settings are set to CD-Player, so that rules out a feedback possibility does anyone know what this problem is? any help or suggestions much appreachated
Look at all the connections.... I mean wires which you have connected. A loose connection could be the reason of Noise. Also, if you have cut the wire somewhere, check that also...
hi thanks for reply ive tried it with my headphones and speakers, i first noticed it on the speakers and then i tested it wiv me headphones it was doin same fyi the connections are straight from the pc there's no amplifier or anything
