update problem
Discussion in 'Linux, BSD and Other OS's' started by gaz2374, Nov 5, 2006.
  1. gaz2374
    gaz2374 Geek Trainee
    updated yesterday and didnt notice the nvidia driver at the bottom anyway cant get into linux now cos the driver is buggered how do i go back to the pre-updated nvidia driver.
  2. sabashuali
    sabashuali Ani Ma'amin
    Have you tried reconfiguring the xserver (or Xorg?)?
    Can you actualy start Linux and log in, even just to command line?
    If you can, try the following line - 'dpkg-reconfigure xserver-xfree86'
    I think you might need to be root.
    I have buggered the xserver a number of times and this worked for me....
  3. gaz2374
    will that work for ubuntu forgot to mention thats the distro im on
  4. gaz2374
    just tried and it says i dont have xserver-xfree86 installed
  5. Addis
    Addis The King
    Do
    Code:
    dpkg-reconfigure --xserver-xorg
    and choose a generic video driver like "nv".
    Alternatively, you could just edit the /etc/X11/xorg.conf and find the section about your screen driver change the line Driver "nvidia" to Driver "nv". That will do the same thing and be a lot quicker.
  6. gaz2374
    thing is i changed it awhile ago to the nvidia driver and it was fine but updated it and it screwed it up.
  7. megamaced
    megamaced Geek Geek Geek!
    Do you mean you upgraded Dapper to Edgy?
  8. gaz2374
    no i just did the updates when u turn it on and says updates ready for the system. still on the same thing just updates a few programs
