Upgraded my RAM- Problem
Discussion in 'CPU, Motherboards and Memory' started by lordstaimot, Dec 17, 2008.
  1. lordstaimot
    lordstaimot Geek Trainee
    Hi all! I'm having some difficulty and was hoping someone would be so kind as to take some time to help me.
    I just bought new RAM, this here: Newegg.com - CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Desktop Memory
    It is CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel.
    I am pretty new to upgrading computers, first of all. So this is what I did: I pulled the old 1g sticks and put these ones in, turned on the computer and checked the system properties in Windows. That's all I thought you had to do.
    It reports the 4g of RAM, but CPU-Z is showing max bandwidth of PC2-6400 (400 MH). That's definitely not what I paid for.
    Any idea how to resolve this?
    Here are my specs:
    Intel Core 2 Quad Q6600 @2.4g
    Asus P5N-E SLI motherboard (With latest BIOS installed that they told me could run PC-8500)
    Nvidia GeForce 8800 GTS
    Windows Vista SP1 32bit
    And then now this new RAM.
    If anyone could help I would be SO grateful.
  2. Sniper
    Hi
    Whats the reported speed in CPU-Z?
    if CPU-Z is showing 533mhz as the memory speed then its running at the stated 1066mhz because DDR doubles the bus speed of the RAM e.g DDR 800 runs @ 400, DDR-667 @ 333.3, DDR-533 @ 266, 1066 @ 533, 900 @ 450)
    Check the ram settings in BIOS, they might be set to AUTO, you should set them to match the memory timings; in you case it should look like 5-5-5-18 oh and you might need to change the memory voltage to 2.1V.
    don't worry about it being reported as PC2-6400 if its running at the stated speed without problems. Also it could be a PC2-6400 designed to run at PC2-8500 speeds but its not had its chip info updated.
  3. lordstaimot
    Well I pulled this info out of the registers dump .txt
    Northbridge NVIDIA nForce 650i SLI SPP rev. A2
    Southbridge NVIDIA nForce 650i SLI MCP rev. A3
    Graphic Interface PCI-Express
    PCI-E Link Width x16
    PCI-E Max Link Width x16
    Memory Type DDR2
    Memory Size 4096 MBytes
    Channels Dual
    Memory Frequency 400.3 MHz (2:3)
    CAS# 5.0
    RAS# to CAS# 5
    RAS# Precharge 5
    Cycle Time (tRAS) 15
    Bank Cycle Time (tRC) 23
    Command Rate 2T
    Memory SPD
    DIMM #1
    General
    Memory type DDR2
    Module format Regular UDIMM
    Manufacturer (ID) Corsair (7F7F9E0000000000)
    Size 2048 MBytes
    Max bandwidth PC2-6400 (400 MHz)
    Part number CM2X2048-8500C5D
    Attributes
    Number of banks 2
    Data width 64 bits
    Correction None
    Nominal Voltage 1.80 Volts
    EPP yes (1 profiles)
    XMP no
    Timings table
    Frequency (MHz) 270 400
    CAS# 4.0 5.0
    RAS# to CAS# delay 4 5
    RAS# Precharge 4 5
    TRAS 13 18
    TRC 16 23
    EPP profile 1 (full)
    Voltage level 2.100 Volts
    Address Command Rate 2T
    Cycle time 1.875 ns (533.3 MHz)
    tCL 5.0 clocks
    tRCD 5 clocks (9.25 ns)
    tRP 5 clocks (9.25 ns)
    tRAS 15 clocks (28.00 ns)
    tRC 22 clocks (41.00 ns)
    tWR 8 clocks (15.00 ns)
    DIMM #2
    General
    Memory type DDR2
    Size 2048 MBytes
    Attributes
    Number of banks 2
    Data width 64 bits
    Correction None
    XMP no
    Timings table
    CAS# 4.0 5.0
    RAS# Precharge 4 5
    TRAS 13 18
    TRC 16 23
    tCL 5.0 clocks
  4. Sniper
    quick search suggests its running at the correct speed, you have to manually set the memory frequency in the BIOS to have it running at 533mhz (1066).
  5. lordstaimot
    So I need to go in the BIOS and make changes? Or are you saying it's running at the speed it should be already?
    I tooled around in there the other day and I didn't see any place to make changes to the speed. Thanks so much for your help with this.
  6. Sniper
    yep in the bios, there must be something in there that indicates the memory speed, that you can change. (maybe under overclocking settings)
    its running at the correct speeds for PC2-6400 ram.
