Urgent Question - Direction L7AK4 17" LCD monitor
Discussion in 'Video Cards, Displays and TV Tuners' started by Karanislove, May 29, 2006.
  1. Karanislove
    [SCMON094] $579.00
    Prices Ex GST & Freight
    Points Credit : 144 points
    Model: L7AK4 Panda
    PANEL: 17" TFT, pixel pitch 0.264mm
    Colors: 16.7M
    Contrast Ratio: 400:1
    Brightness: 250cd/m2
    Viewing Angle Horizontal 150deg / Vertical 140deg
    Response Time: 30ms
    Max. Resolution: 1280*1024
    H-Frequency Range: 30-80kHz
    V-Frequency Range: 55-75Hz
    Power Input: 100-240VAC, 50/60Hz (Adaptor)
    Power Consumption: <48W
    Power Saving: EPA, VESA
    Speaker: 2W*2
    Regulation: UL/CUL, TUV, CCEE, FCC, CE, TCO99
    Plug & Play: DDC2B
    Warranty : 3 bright pixels. You may find upto 3 bright pixels. After that it will be covered under warranty.
    I was looking on an online auction website and found it very cheap for $220.... is it worth buying this LCD TV? Auction will be ending tomorrow.
  2. Marcus_X
    Marcus_X Expert N00b
    It's got horrible response time, shouldn't that be 3ms? Otherwise, you'd end up experiencing ghosting at such high response times. Furthermore there are a lot better monitors new available for a little more than that price.
    The auction's already ended, I hope you didn't buy it?
  3. Karanislove
    Yup, I found it not good and did not go for it. Thanks for your advice anyways~!
