I just installed a new video card, but everytime I turn on my computer, I get an error message stating the there is no video card installed or there is no driver for this card. Can someone please tell me if my configurations are correct? Do I need to change anything in BIOS? I have attached a report for your review: --------[ Summary ]----------------------------------------------------------------------------------------------------- Computer: Operating System Microsoft Windows XP Professional OS Service Pack Service Pack 2 Internet Explorer 6.0.2900.2180 Computer Name HOME User Name Admin Logon Domain HOME Motherboard: CPU Type Intel Pentium 4A, 2666 MHz (5 x 533) Motherboard Name ECS 661FX-M (Deluxe) (3 PCI, 1 AGP, 1 CNR, 2 DIMM, Audio, Video, LAN) Motherboard Chipset SiS 661FX System Memory 1024 MB (DDR SDRAM) BIOS Type Award (06/18/04) Communication Port Communications Port (COM1) Communication Port Communications Port (COM2) Communication Port ECP Printer Port (LPT1) Display: Video Adapter RADEON 9600 SERIES - Secondary (256 MB) Video Adapter RADEON 9600 SERIES (256 MB) 3D Accelerator ATI Radeon 9600 (RV350) Multimedia: Audio Adapter SiS 7012 Audio Device Storage: Floppy Drive Floppy disk drive Disk Drive WDC WD800BB-00CAA1 Optical Drive LITE-ON LTR-52246S (52x/24x/52x CD-RW) Partitions: C: (NTFS) 49999 MB (39891 MB free) --------[ DMI ]--------------------------------------------------------------------------------------------------------- [ BIOS ] BIOS Properties: Vendor Phoenix Technologies, LTD Version 6.00 PG Release Date 06/18/2004 Size 512 KB Boot Devices Floppy Disk, Hard Disk, CD-ROM, ATAPI ZIP, LS-120 Capabilities Flash BIOS, Shadow BIOS, Selectable Boot, EDD Supported Standards DMI, APM, ACPI, PnP Expansion Capabilities ISA, PCI, AGP, USB [ System ] System Properties: Manufacturer SiS Technology Inc. Product SiS661FX + SiS964 Wake-Up Type Power Switch [ Motherboard ] Motherboard Properties: Manufacturer http://www.abit.com.tw Product SG72(SIS 661FX-964L) Version V1.0 [ Chassis ] Chassis Properties: Chassis Type Desktop Case [ Memory Controller ] Memory Controller Properties: Error Detection Method None Error Correction None Supported Memory Interleave 1-Way Current Memory Interleave 1-Way Supported Memory Types DIMM, SDRAM Supported Memory Voltages 3.3V Maximum Memory Module Size 1024 MB Memory Slots 2 [ Processors / Intel(R) Pentium(R) 4 CPU ] Processor Properties: Manufacturer Intel Version Intel(R) Pentium(R) 4 CPU External Clock 133 MHz Current Clock 2666 MHz Type Central Processor Voltage 0.0 V Status Enabled Upgrade ZIF Socket Designation Socket 478 [ Caches / Internal Cache ] Cache Properties: Type Internal Status Enabled Operational Mode Write-Back Maximum Size 20 KB Installed Size 20 KB Supported SRAM Type Synchronous Current SRAM Type Synchronous Socket Designation Internal Cache [ Caches / External Cache ] Cache Properties: Type External Status Enabled Operational Mode Write-Back Maximum Size 512 KB Installed Size 512 KB Supported SRAM Type Synchronous Current SRAM Type Synchronous Socket Designation External Cache [ Memory Modules / A0 ] Memory Module Properties: Socket Designation A0 Type DIMM, SDRAM Installed Size 512 MB Enabled Size 512 MB [ Memory Modules / A1 ] Memory Module Properties: Socket Designation A1 Type DIMM, SDRAM Installed Size 512 MB Enabled Size 512 MB [ Memory Devices / A0 ] Memory Device Properties: Form Factor DIMM Type SDRAM Type Detail Synchronous Size 512 MB Total Width 64-bit Data Width 64-bit Device Locator A0 Bank Locator Bank0/1 [ Memory Devices / A1 ] Memory Device Properties: Form Factor DIMM Type SDRAM Type Detail Synchronous Size 512 MB Total Width 64-bit Data Width 64-bit Device Locator A1 Bank Locator Bank2/3 [ System Slots / PCI0 ] System Slot Properties: Slot Designation PCI0 Type PCI Usage Empty Data Bus Width 32-bit Length Long [ System Slots / PCI1 ] System Slot Properties: Slot Designation PCI1 Type PCI Usage Empty Data Bus Width 32-bit Length Long [ System Slots / PCI2 ] System Slot Properties: Slot Designation PCI2 Type PCI Usage Empty Data Bus Width 32-bit Length Long [ System Slots / PCI3 ] System Slot Properties: Slot Designation PCI3 Type PCI Usage In Use Data Bus Width 32-bit Length Long [ System Slots / AGP ] System Slot Properties: Slot Designation AGP Type AGP Usage Empty Data Bus Width 32-bit Length Long [ Port Connectors / PRIMARY IDE ] Port Connector Properties: Internal Reference Designator PRIMARY IDE Internal Connector Type On-Board IDE External Connector Type None [ Port Connectors / SECONDARY IDE ] Port Connector Properties: Internal Reference Designator SECONDARY IDE Internal Connector Type On-Board IDE External Connector Type None [ Port Connectors / FDD ] Port Connector Properties: Port Type 8251 FIFO Compatible Internal Reference Designator FDD Internal Connector Type On-Board Floppy External Connector Type None [ Port Connectors / COM1 ] Port Connector Properties: Port Type Serial Port 16450 Compatible Internal Reference Designator COM1 Internal Connector Type 9 Pin Dual Inline (pin 10 cut) External Connector Type DB-9 pin male [ Port Connectors / COM2 ] Port Connector Properties: Port Type Serial Port 16450 Compatible Internal Reference Designator COM2 Internal Connector Type 9 Pin Dual Inline (pin 10 cut) External Connector Type DB-9 pin male [ Port Connectors / LPT1 ] Port Connector Properties: Port Type Parallel Port ECP/EPP Internal Reference Designator LPT1 Internal Connector Type DB-25 pin female External Connector Type DB-25 pin female [ Port Connectors / Keyboard ] Port Connector Properties: Port Type Keyboard Port Internal Reference Designator Keyboard Internal Connector Type PS/2 External Connector Type PS/2 [ Port Connectors / PS/2 Mouse ] Port Connector Properties: Port Type Mouse Port Internal Reference Designator PS/2 Mouse Internal Connector Type PS/2 External Connector Type PS/2 [ Port Connectors / USB0 ] Port Connector Properties: Port Type USB Internal Connector Type None External Reference Designator USB0 --------[ Sensor ]------------------------------------------------------------------------------------------------------ Sensor Properties: Sensor Type ITE IT8705F Sensor Access ISA 290h Temperatures: Motherboard 28 °C (82 °F) Aux 21 °C (70 °F) Cooling Fans: CPU 2312 RPM Voltage Values: CPU Core 1.47 V +2.5 V 2.64 V +3.3 V 3.26 V +5 V 5.05 V +12 V 11.01 V +5 V Standby 5.05 V VBAT Battery 3.06 V Debug Info 5C A5 CC BC AC D6 CF BC BF 15 1C C9 (47) --------[ CPU ]--------------------------------------------------------------------------------------------------------- CPU Properties: CPU Type Intel Pentium 4A, 2666 MHz (5 x 533) CPU Alias Northwood, A80532 CPU Stepping D1 Original Clock 2667 MHz L1 Trace Cache 12K Instructions L1 Data Cache 8 KB L2 Cache 512 KB (On-Die, ATC, Full-Speed) CPU Physical Info: Package Type 478 Pin uPGA Package Size 3.50 cm x 3.50 cm Transistors 55 million Process Technology 6M, 0.13 um, CMOS, Cu, Low-K Die Size 131 mm2 Core Voltage 1.475 - 1.55 V I/O Voltage 1.475 - 1.55 V Typical Power 38.7 - 82 W (depending on clock speed) Maximum Power 49 - 103 W (depending on clock speed) CPU Manufacturer: Company Name Intel Corporation Product Information http://www.intel.com/products/browse/processor.htm CPU Utilization: CPU #1 0 % --------[ CPUID ]------------------------------------------------------------------------------------------------------- CPUID Properties: CPUID Manufacturer GenuineIntel CPUID CPU Name Intel(R) Pentium(R) 4 CPU 2.66GHz CPUID Revision 0F29h IA Brand ID 09h (Intel Pentium 4A) Platform ID 0Fh (Socket 478) IA CPU Serial Number Unknown Instruction Set: IA MMX Supported IA SSE Supported IA SSE 2 Supported IA SSE 3 Not Supported CLFLUSH Instruction Supported CMPXCHG8B Instruction Supported CMPXCHG16B Instruction Not Supported Conditional Move Instruction Supported FEMMS Instruction Not Supported MONITOR / MWAIT Instruction Not Supported CPUID Features: 36-bit Page Size Extension Supported Advanced Cryptography Engine Not Supported Alternate Instruction Set Not Supported Automatic Clock Control Supported CPL Qualified Debug Store Not Supported Debug Trace Store Supported Debugging Extension Supported Enhanced SpeedStep Technology Not Supported Fast Save & Restore Supported Fast System Call Supported Hyper-Threading Technology Not Supported L1 Context ID Supported Local APIC On Chip Supported LongRun Not Supported LongRun Table Interface Not Supported Machine-Check Architecture Supported Machine-Check Exception Supported Memory Type Range Registers Supported Model Specific Registers Supported No-Execute Page Protection Not Supported Page Attribute Table Supported Page Global Extension Supported Page Size Extension Supported Pending Break Event Supported Physical Address Extension Supported Processor Duty Cycle Control Supported Processor Serial Number Not Supported Random Number Generator Not Supported Self-Snoop Supported Thermal Monitor Supported Thermal Monitor 2 Not Supported Time Stamp Counter Supported Virtual Mode Extension Supported --------[ Motherboard ]------------------------------------------------------------------------------------------------- Motherboard Properties: Motherboard ID 06/18/2004-SiS-661-6A7I4E1AC-13 Motherboard Name ECS 661FX-M (Deluxe) Front Side Bus Properties: Bus Type Intel NetBurst Bus Width 64-bit Real Clock 133 MHz (QDR) Effective Clock 533 MHz Bandwidth 4266 MB/s Chipset Bus Properties: Bus Type SiS MuTIOL Bus Width 16-bit Motherboard Physical Info: CPU Sockets/Slots 1 Expansion Slots 3 PCI, 1 AGP, 1 CNR RAM Slots 2 DIMM Integrated Devices Audio, Video, LAN Form Factor Micro ATX Motherboard Size 230 mm x 240 mm Motherboard Chipset SiS661FX Motherboard Manufacturer: Company Name Elitegroup Computer Systems Product Information http://www.ecs.com.tw/products/pd_list.asp?submenu_id=4&function_id=1 BIOS Download http://www.ecs.com.tw/download/dw_list.asp?submenu_id=23&function_id=1 --------[ Memory ]------------------------------------------------------------------------------------------------------ Physical Memory: Total 1023 MB Used 234 MB Free 789 MB Utilization 23 % Swap Space: Total 2462 MB Used 132 MB Free 2329 MB Utilization 5 % Virtual Memory: Total 3485 MB Used 366 MB Free 3119 MB Utilization 11 % --------[ Chipset ]----------------------------------------------------------------------------------------------------- Chipset Properties: Motherboard Chipset SiS 661FX CAS Latency 2.5T RAS To CAS Delay 3T RAS Precharge 3T RAS Active Time 6T Memory Slots: DRAM Slot #1 512 MB (DDR SDRAM) DRAM Slot #2 512 MB (DDR SDRAM) AGP Properties: AGP Version 3.05 AGP Status Enabled AGP Aperture Size 128 MB Supported AGP Speeds 1x, 2x, 4x, 8x Current AGP Speed 8x Fast-Write Not Supported Side Band Addressing Supported, Enabled Chipset Manufacturer: Company Name Silicon Integrated Systems Corporation Product Information http://www.sis.com/products/index.htm#chipsets Driver Download http://download.sis.com/index_step1.php --------[ BIOS ]-------------------------------------------------------------------------------------------------------- BIOS Properties: BIOS Type Award Award BIOS Type Phoenix - AwardBIOS v6.00PG Award BIOS Message Phoenix - AwardBIOS v6.00P System BIOS Date 06/18/04 Video BIOS Date 04/01/15 BIOS Manufacturer: Company Name Phoenix Technologies Ltd. Product Information http://www.phoenix.com/en/products/default.htm --------[ Windows Video ]----------------------------------------------------------------------------------------------- [ RADEON 9600 SERIES - Secondary ] Video Adapter Properties: Device Description RADEON 9600 SERIES - Secondary Adapter String RADEON 9600 SERIES BIOS String BK-ATI VER008.015.058.000 Chip Type RADEON 9600 Series AGP (0x4150) DAC Type Internal DAC(400MHz) Installed Drivers ati2dvag (6.14.10.6444) Memory Size 256 MB Video Adapter Manufacturer: Company Name ATI Technologies Inc. Product Information http://www.ati.com/products/home-office.html Driver Download http://www.ati.com/support/driver.html [ RADEON 9600 SERIES ] Video Adapter Properties: Device Description RADEON 9600 SERIES Adapter String RADEON 9600 SERIES BIOS String BK-ATI VER008.015.058.000 Chip Type RADEON 9600 Series AGP (0x4150) DAC Type Internal DAC(400MHz) Installed Drivers ati2dvag (6.14.10.6444) Memory Size 256 MB Video Adapter Manufacturer: Company Name ATI Technologies Inc. Product Information http://www.ati.com/products/home-office.html Driver Download http://www.ati.com/support/driver.html --------[ PCI / AGP Video ]--------------------------------------------------------------------------------------------- ATI Radeon 9600 (RV350) Video Adapter ATI Radeon 9600 (RV350) 3D Accelerator --------[ GPU ]--------------------------------------------------------------------------------------------------------- Graphics Processor Properties: Video Adapter ATI Radeon 9600 (RV350) GPU Code Name RV350 PCI Device 1002 / 4150 Transistors 76 million Process Technology 0.13u Bus Type AGP Memory Size 256 MB GPU Clock 392 MHz RAMDAC Clock 400 MHz Pixel Pipelines 4 TMU Per Pipeline 1 Vertex Shaders 2 (v2.0) Pixel Shaders 1 (v2.0) DirectX Hardware Support DirectX v9.0 Pixel Fillrate 1568 MPixel/s Texel Fillrate 1568 MTexel/s Memory Bus Properties: Bus Type DDR Bus Width 128-bit Real Clock 202 MHz (DDR) Effective Clock 404 MHz Bandwidth 6464 MB/s Graphics Processor Manufacturer: Company Name ATI Technologies Inc. Product Information http://www.ati.com/products/home-office.html Driver Download http://www.ati.com/support/driver.html --------[ Desktop ]----------------------------------------------------------------------------------------------------- Desktop Properties: Device Technology Raster Display Resolution 1024 x 768 Color Depth 32-bit Color Planes 1 Font Resolution 96 dpi Pixel Width / Height 36 / 36 Pixel Diagonal 51 Vertical Refresh Rate Default Desktop Wallpaper C:\WINDOWS\web\wallpaper\Bliss.bmp Desktop Effects: Combo-Box Animation Enabled Drop Shadow Effect Enabled Flat Menu Effect Enabled Font Smoothing Enabled Full Window Dragging Enabled Gradient Window Title Bars Enabled Hide Menu Access Keys Enabled Hot Tracking Effect Enabled Icon Title Wrapping Enabled List-Box Smooth Scrolling Enabled Menu Animation Enabled Menu Fade Effect Enabled Minimize/Restore Animation Enabled Mouse Cursor Shadow Enabled Selection Fade Effect Enabled ShowSounds Accessibility Feature Disabled ToolTip Animation Enabled ToolTip Fade Effect Enabled Windows Plus! Extension Disabled --------[ Multi-Monitor ]----------------------------------------------------------------------------------------------- \\.\DISPLAY1 Yes (0,0) (1024,768) --------[ Windows Audio ]----------------------------------------------------------------------------------------------- midi-out.0 0001 0066 Microsoft GS Wavetable SW Synth mixer.0 FFFF FFFF Realtek AC97 Audio wave-in.0 FFFF FFFF Realtek AC97 Audio wave-out.0 FFFF FFFF Realtek AC97 Audio --------[ PCI / PnP Audio ]--------------------------------------------------------------------------------------------- SiS 7012 Audio Device PCI --------[ Windows Storage ]--------------------------------------------------------------------------------------------- [ Floppy disk drive ] Device Properties: Driver Description Floppy disk drive Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File flpydisk.inf [ WDC WD800BB-00CAA1 ] Device Properties: Driver Description WDC WD800BB-00CAA1 Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File disk.inf Device Manufacturer: Company Name Western Digital Corporation Product Information http://www.westerndigital.com/en/products [ LITE-ON LTR-52246S ] Device Properties: Driver Description LITE-ON LTR-52246S Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File cdrom.inf Optical Drive Properties: Manufacturer Lite-On Device Type CD-RW Speed 52x/24x/52x Device Manufacturer: Company Name LITE-ON IT Corp. Product Information http://www.liteon.com/prod/productIndex.do?xml_id=4 [ Primary IDE Channel ] Device Properties: Driver Description Primary IDE Channel Driver Date 7/1/2001 Driver Version 5.1.2600.1106 Driver Provider Microsoft INF File mshdc.inf Device Resources: IRQ 14 Port 01F0-01F7 Port 03F6-03F6 [ Secondary IDE Channel ] Device Properties: Driver Description Secondary IDE Channel Driver Date 7/1/2001 Driver Version 5.1.2600.1106 Driver Provider Microsoft INF File mshdc.inf Device Resources: IRQ 15 Port 0170-0177 Port 0376-0376 [ SiS 5513 IDE UDMA Controller ] Device Properties: Driver Description SiS 5513 IDE UDMA Controller Driver Date 9/15/2003 Driver Version 5.1.1039.2041 Driver Provider Silicon Integrated Systems Corp. INF File oem4.inf Device Resources: Port 4000-400F --------[ Logical Drives ]---------------------------------------------------------------------------------------------- A: Removable Disk C: Local Disk NTFS 84A2-8F49 49999 MB 39891 MB 80 % D: Optical Drive --------[ Physical Drives ]--------------------------------------------------------------------------------------------- [ Drive #1 (74.5 GB) ] #1 (Active) NTFS C: 0 MB 49999 MB --------[ Optical Drives ]---------------------------------------------------------------------------------------------- LITE-ON LTR-52246S Lite-On CD-RW 52x/24x/52x --------[ ASPI ]-------------------------------------------------------------------------------------------------------- 00 00 00 Disk Drive WDC WD80 0BB-00CAA1 00 07 00 Host Adapter atapi 01 01 00 Optical Drive LITE-ON LTR-52246S 01 07 00 Host Adapter atapi --------[ ATA ]--------------------------------------------------------------------------------------------------------- [ WDC WD800BB-00CAA1 (WD-WMA8E8823325) ] ATA Device Properties: Model ID WDC WD800BB-00CAA1 Serial Number WD-WMA8E8823325 Revision 17.07W17 Parameters 155061 cylinders, 16 heads, 63 sectors per track, 600 bytes per sector LBA Sectors 156301488 Buffer 2 MB (Dual Ported, Read Ahead) Multiple Sectors 16 ECC Bytes 40 Max. PIO Transfer Mode PIO 4 Max. UDMA Transfer Mode UDMA 5 (ATA-100) Active UDMA Transfer Mode UDMA 2 (ATA-33) Unformatted Capacity 89436 MB ATA Device Features: SMART Supported Security Mode Supported Power Management Supported Advanced Power Management Not Supported Write Cache Supported Host Protected Area Supported Power-Up In Standby Not Supported Automatic Acoustic Management Supported 48-bit LBA Not Supported Device Configuration Overlay Supported ATA Device Manufacturer: Company Name Western Digital Corporation Product Information http://www.westerndigital.com/en/products --------[ SMART ]------------------------------------------------------------------------------------------------------- [ WDC WD800BB-00CAA1 (WD-WMA8E8823325) ] 01 Raw Read Error Rate 51 200 200 0 OK: Value is normal 03 Spin Up Time 21 109 96 3641 OK: Value is normal 04 Start/Stop Count 40 100 100 159 OK: Value is normal 05 Reallocated Sector Count 140 200 200 0 OK: Value is normal 07 Seek Error Rate 51 100 253 0 OK: Value is normal 09 Power-On Time Count 0 94 94 4395 OK: Always passing 0A Spin Retry Count 51 100 100 0 OK: Value is normal 0B Calibration Retry Count 51 100 100 0 OK: Value is normal 0C Power Cycle Count 0 100 100 152 OK: Always passing C4 Reallocation Event Count 0 200 200 0 OK: Always passing C5 Current Pending Sector Count 0 200 200 0 OK: Always passing C6 Off-Line Uncorrectable Sector Count 0 200 200 0 OK: Always passing C7 Ultra ATA CRC Error Rate 0 200 200 0 OK: Always passing C8 Write Error Rate 51 200 200 0 OK: Value is normal --------[ Windows Network ]--------------------------------------------------------------------------------------------- [ Realtek RTL8139 Family PCI Fast Ethernet NIC ] Network Adapter Properties: Network Adapter Realtek RTL8139 Family PCI Fast Ethernet NIC Interface Type Ethernet Hardware Address 00-50-8D-A3-20-0C Connection Name Local Area Connection Connection Speed 10 Mbps MTU 1500 bytes DHCP Lease Obtained 12/18/2004 9:07:29 PM DHCP Lease Expires 12/18/2004 10:07:29 PM Bytes Received 104013 (101.6 KB) Bytes Sent 39236 (38.3 KB) Network Adapter Manufacturer: Company Name Realtek Semiconductor Corp. Product Information http://www.realtek.com.tw/products/products1-1.aspx?lineid=1 Driver Download http://www.realtek.com.tw/downloads/downloads1-1.aspx?lineid=1 --------[ PCI / PnP Network ]------------------------------------------------------------------------------------------- Realtek RTL8139 Fast Ethernet Adapter PCI --------[ DirectX Video ]----------------------------------------------------------------------------------------------- [ Primary Display Driver ] DirectDraw Device Properties: DirectDraw Driver Name display DirectDraw Driver Description Primary Display Driver Hardware Driver vga.dll Hardware Description --------[ DirectX Sound ]----------------------------------------------------------------------------------------------- [ Primary Sound Driver ] DirectSound Device Properties: Device Description Primary Sound Driver Driver Module Primary Buffers 1 Min / Max Secondary Buffers Sample Rate 100 / 192000 Hz Primary Buffers Sound Formats 8-bit, 16-bit, Mono, Stereo Secondary Buffers Sound Formats 8-bit, 16-bit, Mono, Stereo Total / Free Sound Buffers 33 / 32 Total / Free Static Sound Buffers 33 / 32 Total / Free Streaming Sound Buffers 33 / 32 Total / Free 3D Sound Buffers 33 / 32 Total / Free 3D Static Sound Buffers 33 / 32 Total / Free 3D Streaming Sound Buffers 33 / 32 DirectSound Device Features: Certified Driver Yes Emulated Device No Precise Sample Rate Supported [ Realtek AC97 Audio ] DirectSound Device Properties: Device Description Realtek AC97 Audio Driver Module ALCXWDM.SYS Primary Buffers 1 Min / Max Secondary Buffers Sample Rate 100 / 192000 Hz Primary Buffers Sound Formats 8-bit, 16-bit, Mono, Stereo Secondary Buffers Sound Formats 8-bit, 16-bit, Mono, Stereo Total / Free Sound Buffers 33 / 32 Total / Free Static Sound Buffers 33 / 32 Total / Free Streaming Sound Buffers 33 / 32 Total / Free 3D Sound Buffers 33 / 32 Total / Free 3D Static Sound Buffers 33 / 32 Total / Free 3D Streaming Sound Buffers 33 / 32 DirectSound Device Features: Certified Driver Yes Emulated Device No Precise Sample Rate Supported --------[ DirectX Music ]----------------------------------------------------------------------------------------------- [ Realtek AC97 Audio ] DirectMusic Device Properties: Device Description Realtek AC97 Audio Synthesizer Type Software Device Class Output Port Device Type WDM Multimedia Audio Channels 2 MIDI Channels 16000 Voices 1000 Available Memory System Memory DirectMusic Device Features: Built-In GM Instrument Set No Built-In Roland GS Sound Set No DirectSound Not Supported DLS L1 Sample Collections Supported DLS L2 Sample Collections Not Supported External MIDI Port No Fixed DLS Memory Size No Port Sharing Not Supported Chorus Effect Not Supported Delay Effect Not Supported Reverb Effect Supported [ Microsoft MIDI Mapper [Emulated] ] DirectMusic Device Properties: Device Description Microsoft MIDI Mapper [Emulated] Synthesizer Type Hardware Device Class Output Port Device Type Windows Multimedia MIDI Channels 16 DirectMusic Device Features: Built-In GM Instrument Set No Built-In Roland GS Sound Set No DirectSound Not Supported DLS L1 Sample Collections Not Supported DLS L2 Sample Collections Not Supported External MIDI Port No Fixed DLS Memory Size No Port Sharing Supported Chorus Effect Not Supported Delay Effect Not Supported Reverb Effect Not Supported [ Microsoft GS Wavetable SW Synth [Emulated] ] DirectMusic Device Properties: Device Description Microsoft GS Wavetable SW Synth [Emulated] Synthesizer Type Hardware Device Class Output Port Device Type Windows Multimedia MIDI Channels 16 DirectMusic Device Features: Built-In GM Instrument Set No Built-In Roland GS Sound Set No DirectSound Not Supported DLS L1 Sample Collections Not Supported DLS L2 Sample Collections Not Supported External MIDI Port No Fixed DLS Memory Size No Port Sharing Supported Chorus Effect Not Supported Delay Effect Not Supported Reverb Effect Not Supported [ Microsoft Synthesizer ] DirectMusic Device Properties: Device Description Microsoft Synthesizer Synthesizer Type Software Device Class Output Port Device Type User-Mode Synthesizer Audio Channels 2 MIDI Channels 16000 Voices 1000 Available Memory System Memory DirectMusic Device Features: Built-In GM Instrument Set No Built-In Roland GS Sound Set No DirectSound Supported DLS L1 Sample Collections Supported DLS L2 Sample Collections Supported External MIDI Port No Fixed DLS Memory Size No Port Sharing Not Supported Chorus Effect Not Supported Delay Effect Not Supported Reverb Effect Supported --------[ DirectX Input ]----------------------------------------------------------------------------------------------- [ Mouse ] DirectInput Device Properties: Device Description Mouse Device Type Mouse Device Subtype Unknown Axes 2 Buttons/Keys 3 DirectInput Device Features: Emulated Device Yes Alias Device No Polled Device No Polled Data Format No Attack Force Feedback Not Supported Deadband Force Feedback Not Supported Fade Force Feedback Not Supported Force Feedback Not Supported Saturation Force Feedback Not Supported +/- Force Feedback Coefficients Not Supported +/- Force Feedback Saturation Not Supported [ Keyboard ] DirectInput Device Properties: Device Description Keyboard Device Type Keyboard Device Subtype IBM PC Enhanced 101/102-key or Microsoft Natural keyboard Buttons/Keys 128 DirectInput Device Features: Emulated Device Yes Alias Device No Polled Device No Polled Data Format No Attack Force Feedback Not Supported Deadband Force Feedback Not Supported Fade Force Feedback Not Supported Force Feedback Not Supported Saturation Force Feedback Not Supported +/- Force Feedback Coefficients Not Supported +/- Force Feedback Saturation Not Supported --------[ Windows Devices ]--------------------------------------------------------------------------------------------- [ Devices ] Computer: ACPI Uniprocessor PC 5.1.2600.0 Disk drives: WDC WD800BB-00CAA1 5.1.2535.0 Display adapters: RADEON 9600 SERIES 6.14.10.6444 RADEON 9600 SERIES - Secondary 6.14.10.6444 DVD/CD-ROM drives: LITE-ON LTR-52246S 5.1.2535.0 Floppy disk controllers: Standard floppy disk controller 5.1.2600.0 Floppy disk drives: Floppy disk drive 5.1.2600.0 IDE ATA/ATAPI controllers: Primary IDE Channel 5.1.2600.1106 Secondary IDE Channel 5.1.2600.1106 SiS 5513 IDE UDMA Controller 5.1.1039.2041 Keyboards: Easy Internet Keyboard 2.15.0.0 Mice and other pointing devices: Logitech-compatible Mouse PS/2 9.75.0.0 Network adapters: Direct Parallel 5.1.2535.0 Realtek RTL8139 Family PCI Fast Ethernet NIC 5.396.530.2001 Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport5.1.2535.0 WAN Miniport (IP) 5.1.2535.0 WAN Miniport (IP) - Packet Scheduler Miniport 5.1.2535.0 WAN Miniport (L2TP) 5.1.2535.0 WAN Miniport (PPPOE) 5.1.2535.0 WAN Miniport (PPTP) 5.1.2535.0 Non-Plug and Play Drivers: AC2003 AFD Networking Support Environment AVG Network Redirector AVG7 Kernel AVG7 Rezident Driver AVG7 Wrap Driver Beep dmboot dmload Fips Generic Packet Classifier HTTP IP Network Address Translator IPSEC driver ksecdd mnmdd mountmgr NDIS System Driver NDIS Usermode I/O Protocol NDProxy NetBios over Tcpip Null PartMgr ParVdm PCIIde RDPCDD Remote Access Auto Connection Driver Remote Access IP ARP Driver Remote Access NDIS TAPI Driver TCP/IP Protocol Driver VgaSave VolSnap Ports (COM & LPT): Communications Port (COM1) 5.1.2600.0 Communications Port (COM2) 5.1.2600.0 ECP Printer Port (LPT1) 5.1.2600.0 Processors: Intel(R) Pentium(R) 4 CPU 2.66GHz 5.1.2600.0 Sound, video and game controllers: Audio Codecs 5.1.2535.0 Legacy Audio Drivers 5.1.2535.0 Legacy Video Capture Devices 5.1.2535.0 Media Control Devices 5.1.2535.0 Microsoft Kernel System Audio Device 5.1.2535.0 Microsoft Kernel Wave Audio Mixer 5.1.2535.0 Microsoft WINMM WDM Audio Compatibility Driver 5.1.2535.0 Realtek AC'97 Audio 5.10.0.5630 Video Codecs 5.1.2535.0 Storage volumes: Generic volume 5.1.2600.0 System devices: ACPI Fan 5.1.2600.0 ACPI Fixed Feature Button 5.1.2600.0 ACPI Power Button 5.1.2600.0 ACPI Sleep Button 5.1.2600.0 ACPI Thermal Zone 5.1.2600.0 Direct memory access controller 5.1.2600.0 ISAPNP Read Data Port 5.1.2600.0 Logical Disk Manager 5.1.2600.0 Microcode Update Device 5.1.2600.0 Microsoft ACPI-Compliant System 5.1.2535.0 Microsoft System Management BIOS Driver 5.1.2600.2180 Motherboard resources 5.1.2600.0 Numeric data processor 5.1.2600.0 PCI bus 5.1.2600.0 PCI standard host CPU bridge 5.1.2600.0 PCI standard ISA bridge 5.1.2600.0 Plug and Play Software Device Enumerator 5.1.2600.0 Printer Port Logical Interface 5.1.2600.0 Programmable interrupt controller 5.1.2600.0 SiS Accelerated Graphics Port 7.2.0.1170 System board 5.1.2600.0 System CMOS/real time clock 5.1.2600.0 System speaker 5.1.2600.0 System timer 5.1.2600.0 Terminal Server Device Redirector 5.1.2600.0 Terminal Server Keyboard Driver 5.1.2600.0 Terminal Server Mouse Driver 5.1.2600.0 Volume Manager 5.1.2600.0 Universal Serial Bus controllers: SiS 7001 PCI to USB Open Host Controller 5.1.2600.1106 SiS 7001 PCI to USB Open Host Controller 5.1.2600.1106 SiS 7001 PCI to USB Open Host Controller 5.1.2600.1106 SiS PCI to USB Enhanced Host Controller 5.1.2600.0 USB Root Hub 5.1.2600.1106 USB Root Hub 5.1.2600.1106 USB Root Hub 5.1.2600.1106 USB Root Hub 5.1.2600.1106 [ Computer / ACPI Uniprocessor PC ] Device Properties: Driver Description ACPI Uniprocessor PC Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File hal.inf [ Disk drives / WDC WD800BB-00CAA1 ] Device Properties: Driver Description WDC WD800BB-00CAA1 Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File disk.inf [ Display adapters / RADEON 9600 SERIES ] Device Properties: Driver Description RADEON 9600 SERIES Driver Date 4/21/2004 Driver Version 6.14.10.6444 Driver Provider ATI Technologies Inc. INF File oem1.inf Device Resources: IRQ 16 Memory 000A0000-000BFFFF Memory C0000000-CFFFFFFF Memory E9000000-E900FFFF Port 03B0-03BB Port 03C0-03DF Port D000-D0FF [ Display adapters / RADEON 9600 SERIES - Secondary ] Device Properties: Driver Description RADEON 9600 SERIES - Secondary Driver Date 4/21/2004 Driver Version 6.14.10.6444 Driver Provider ATI Technologies Inc. INF File oem1.inf Device Resources: Memory D0000000-DFFFFFFF Memory E9FF0000-E9FFFFFF [ DVD/CD-ROM drives / LITE-ON LTR-52246S ] Device Properties: Driver Description LITE-ON LTR-52246S Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File cdrom.inf [ Floppy disk controllers / Standard floppy disk controller ] Device Properties: Driver Description Standard floppy disk controller Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File fdc.inf Device Resources: DMA 02 IRQ 06 Port 03F0-03F5 Port 03F7-03F7 [ Floppy disk drives / Floppy disk drive ] Device Properties: Driver Description Floppy disk drive Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File flpydisk.inf [ IDE ATA/ATAPI controllers / Primary IDE Channel ] Device Properties: Driver Description Primary IDE Channel Driver Date 7/1/2001 Driver Version 5.1.2600.1106 Driver Provider Microsoft INF File mshdc.inf Device Resources: IRQ 14 Port 01F0-01F7 Port 03F6-03F6 [ IDE ATA/ATAPI controllers / Secondary IDE Channel ] Device Properties: Driver Description Secondary IDE Channel Driver Date 7/1/2001 Driver Version 5.1.2600.1106 Driver Provider Microsoft INF File mshdc.inf Device Resources: IRQ 15 Port 0170-0177 Port 0376-0376 [ IDE ATA/ATAPI controllers / SiS 5513 IDE UDMA Controller ] Device Properties: Driver Description SiS 5513 IDE UDMA Controller Driver Date 9/15/2003 Driver Version 5.1.1039.2041 Driver Provider Silicon Integrated Systems Corp. INF File oem4.inf Device Resources: Port 4000-400F Device Resources: IRQ 01 Port 0060-0060 Port 0064-0064 [ Network adapters / Direct Parallel ] Device Properties: Driver Description Direct Parallel Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File netrasa.inf [ Network adapters / Realtek RTL8139 Family PCI Fast Ethernet NIC ] Device Properties: Driver Description Realtek RTL8139 Family PCI Fast Ethernet NIC Driver Date 7/1/2001 Driver Version 5.396.530.2001 Driver Provider Microsoft INF File netrtsnt.inf Device Resources: IRQ 18 Memory EA004000-EA0040FF Port E800-E8FF [ Network adapters / Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport ] Device Properties: Driver Description Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File netpsa.inf [ Network adapters / WAN Miniport (IP) ] Device Properties: Driver Description WAN Miniport (IP) Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File netrasa.inf [ Network adapters / WAN Miniport (IP) - Packet Scheduler Miniport ] Device Properties: Driver Description WAN Miniport (IP) - Packet Scheduler Miniport Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File netpsa.inf [ Network adapters / WAN Miniport (L2TP) ] Device Properties: Driver Description WAN Miniport (L2TP) Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File netrasa.inf [ Network adapters / WAN Miniport (PPPOE) ] Device Properties: Driver Description WAN Miniport (PPPOE) Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File netrasa.inf [ Network adapters / WAN Miniport (PPTP) ] Device Properties: Driver Description WAN Miniport (PPTP) Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File netrasa.inf [ Ports (COM & LPT) / Communications Port (COM1) ] Device Properties: Driver Description Communications Port (COM1) Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File msports.inf Device Resources: IRQ 04 Port 03F8-03FF [ Ports (COM & LPT) / Communications Port (COM2) ] Device Properties: Driver Description Communications Port (COM2) Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File msports.inf Device Resources: IRQ 03 Port 02F8-02FF [ Ports (COM & LPT) / ECP Printer Port (LPT1) ] Device Properties: Driver Description ECP Printer Port (LPT1) Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File msports.inf Device Resources: DMA 03 Port 0378-037F Port 0778-077B [ Processors / Intel(R) Pentium(R) 4 CPU 2.66GHz ] Device Properties: Driver Description Intel(R) Pentium(R) 4 CPU 2.66GHz Driver Date 4/1/2004 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File cpu.inf [ Sound, video and game controllers / Audio Codecs ] Device Properties: Driver Description Audio Codecs Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File wave.inf [ Sound, video and game controllers / Legacy Audio Drivers ] Device Properties: Driver Description Legacy Audio Drivers Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File wave.inf [ Sound, video and game controllers / Legacy Video Capture Devices ] Device Properties: Driver Description Legacy Video Capture Devices Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File wave.inf [ Sound, video and game controllers / Media Control Devices ] Device Properties: Driver Description Media Control Devices Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File wave.inf [ Sound, video and game controllers / Microsoft Kernel System Audio Device ] Device Properties: Driver Description Microsoft Kernel System Audio Device Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File wdmaudio.inf [ Sound, video and game controllers / Microsoft Kernel Wave Audio Mixer ] Device Properties: Driver Description Microsoft Kernel Wave Audio Mixer Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File wdmaudio.inf [ Sound, video and game controllers / Microsoft WINMM WDM Audio Compatibility Driver ] Device Properties: Driver Description Microsoft WINMM WDM Audio Compatibility Driver Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File wdmaudio.inf [ Sound, video and game controllers / Realtek AC'97 Audio ] Device Properties: Driver Description Realtek AC'97 Audio Driver Date 7/1/2004 Driver Version 5.10.0.5630 Driver Provider Realtek Semiconductor Corp. INF File oem2.inf Device Resources: IRQ 18 Port E000-E0FF Port E400-E47F [ Sound, video and game controllers / Video Codecs ] Device Properties: Driver Description Video Codecs Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File wave.inf [ Storage volumes / Generic volume ] Device Properties: Driver Description Generic volume Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File volume.inf [ System devices / ACPI Fan ] Device Properties: Driver Description ACPI Fan Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ System devices / ACPI Fixed Feature Button ] Device Properties: Driver Description ACPI Fixed Feature Button Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ System devices / ACPI Power Button ] Device Properties: Driver Description ACPI Power Button Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ System devices / ACPI Sleep Button ] Device Properties: Driver Description ACPI Sleep Button Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ System devices / ACPI Thermal Zone ] Device Properties: Driver Description ACPI Thermal Zone Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ System devices / Direct memory access controller ] Device Properties: Driver Description Direct memory access controller Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf Device Resources: DMA 04 Port 0000-000F Port 0080-0090 Port 0094-009F Port 00C0-00DF [ System devices / ISAPNP Read Data Port ] Device Properties: Driver Description ISAPNP Read Data Port Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf Device Resources: Port 0274-0277 Port 0279-0279 Port 0A79-0A79 [ System devices / Logical Disk Manager ] Device Properties: Driver Description Logical Disk Manager Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ System devices / Microcode Update Device ] Device Properties: Driver Description Microcode Update Device Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ System devices / Microsoft ACPI-Compliant System ] Device Properties: Driver Description Microsoft ACPI-Compliant System Driver Date 7/1/2001 Driver Version 5.1.2535.0 Driver Provider Microsoft INF File acpi.inf Device Resources: IRQ 09 [ System devices / Microsoft System Management BIOS Driver ] Device Properties: Driver Description Microsoft System Management BIOS Driver Driver Date 7/1/2001 Driver Version 5.1.2600.2180 Driver Provider Microsoft INF File machine.inf [ System devices / Motherboard resources ] Device Properties: Driver Description Motherboard resources Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ System devices / Numeric data processor ] Device Properties: Driver Description Numeric data processor Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf Device Resources: IRQ 13 Port 00F0-00FF [ System devices / PCI bus ] Device Properties: Driver Description PCI bus Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf Device Resources: Memory 000A0000-000BFFFF Memory 40000000-FEBFFFFF Port 0000-047F Port 0490-0CF7 Port 0D00-0FFF Port 1100-FFFF [ System devices / PCI standard host CPU bridge ] Device Properties: Driver Description PCI standard host CPU bridge Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ System devices / PCI standard ISA bridge ] Device Properties: Driver Description PCI standard ISA bridge Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ System devices / Plug and Play Software Device Enumerator ] Device Properties: Driver Description Plug and Play Software Device Enumerator Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ System devices / Printer Port Logical Interface ] Device Properties: Driver Description Printer Port Logical Interface Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ System devices / Programmable interrupt controller ] Device Properties: Driver Description Programmable interrupt controller Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf Device Resources: Port 0020-0021 Port 00A0-00A1 [ System devices / SiS Accelerated Graphics Port ] Device Properties: Driver Description SiS Accelerated Graphics Port Driver Date 7/18/2003 Driver Version 7.2.0.1170 Driver Provider SiS INF File oem3.inf Device Resources: Memory 000A0000-000BFFFF Memory C0000000-DFFFFFFF Memory E0000000-E7FFFFFF Memory E8000000-E9FFFFFF Port 03B0-03BB Port 03C0-03DF Port D000-DFFF [ System devices / System board ] Device Properties: Driver Description System board Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf Device Resources: Memory 00000000-0009FFFF Memory 000CD000-000CFFFF Memory 000F0000-000F7FFF Memory 000F8000-000FBFFF Memory 000FC000-000FFFFF Memory 00100000-3FFEFFFF Memory 3FFF0000-3FFFFFFF Memory FEC00000-FECFFFFF Memory FEE00000-FEEFFFFF Memory FFEE0000-FFEFFFFF Memory FFFE0000-FFFEFFFF Memory FFFF0000-FFFFFFFF [ System devices / System CMOS/real time clock ] Device Properties: Driver Description System CMOS/real time clock Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf Device Resources: IRQ 08 Port 0070-0073 [ System devices / System speaker ] Device Properties: Driver Description System speaker Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf Device Resources: Port 0061-0061 [ System devices / System timer ] Device Properties: Driver Description System timer Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf Device Resources: IRQ 00 Port 0040-0043 [ System devices / Terminal Server Device Redirector ] Device Properties: Driver Description Terminal Server Device Redirector Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ System devices / Terminal Server Keyboard Driver ] Device Properties: Driver Description Terminal Server Keyboard Driver Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ System devices / Terminal Server Mouse Driver ] Device Properties: Driver Description Terminal Server Mouse Driver Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ System devices / Volume Manager ] Device Properties: Driver Description Volume Manager Driver Date 7/1/2001 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File machine.inf [ Universal Serial Bus controllers / SiS 7001 PCI to USB Open Host Controller ] Device Properties: Driver Description SiS 7001 PCI to USB Open Host Controller Driver Date 7/1/2001 Driver Version 5.1.2600.1106 Driver Provider Microsoft INF File usbport.inf Device Resources: IRQ 21 Memory EA001000-EA001FFF [ Universal Serial Bus controllers / SiS 7001 PCI to USB Open Host Controller ] Device Properties: Driver Description SiS 7001 PCI to USB Open Host Controller Driver Date 7/1/2001 Driver Version 5.1.2600.1106 Driver Provider Microsoft INF File usbport.inf Device Resources: IRQ 20 Memory EA000000-EA000FFF [ Universal Serial Bus controllers / SiS 7001 PCI to USB Open Host Controller ] Device Properties: Driver Description SiS 7001 PCI to USB Open Host Controller Driver Date 7/1/2001 Driver Version 5.1.2600.1106 Driver Provider Microsoft INF File usbport.inf Device Resources: IRQ 22 Memory EA002000-EA002FFF [ Universal Serial Bus controllers / SiS PCI to USB Enhanced Host Controller ] Device Properties: Driver Description SiS PCI to USB Enhanced Host Controller Driver Date 6/1/2002 Driver Version 5.1.2600.0 Driver Provider Microsoft INF File usbport.inf Device Resources: IRQ 23 Memory EA003000-EA003FFF [ Universal Serial Bus controllers / USB Root Hub ] Device Properties: Driver Description USB Root Hub Driver Date 7/1/2001 Driver Version 5.1.2600.1106 Driver Provider Microsoft INF File usbport.inf [ Universal Serial Bus controllers / USB Root Hub ] Device Properties: Driver Description USB Root Hub Driver Date 7/1/2001 Driver Version 5.1.2600.1106 Driver Provider Microsoft INF File usbport.inf [ Universal Serial Bus controllers / USB Root Hub ] Device Properties: Driver Description USB Root Hub Driver Date 7/1/2001 Driver Version 5.1.2600.1106 Driver Provider Microsoft INF File usbport.inf [ Universal Serial Bus controllers / USB Root Hub ] Device Properties: Driver Description USB Root Hub Driver Date 7/1/2001 Driver Version 5.1.2600.1106 Driver Provider Microsoft INF File usbport.inf --------[ Physical Devices ]-------------------------------------------------------------------------------------------- PCI Devices: Bus 1, Device 0, Function 1 ATI Radeon 9600 (RV350) - Secondary Video Adapter Bus 1, Device 0, Function 0 ATI Radeon 9600 (RV350) Video Adapter Bus 0, Device 14, Function 0 Realtek RTL8139 Fast Ethernet Adapter Bus 0, Device 0, Function 0 SiS 661FX Chipset - Host-PCI Bridge Bus 0, Device 3, Function 0 SiS 7001 PCI-USB Open Host Controller Bus 0, Device 3, Function 1 SiS 7001 PCI-USB Open Host Controller Bus 0, Device 3, Function 2 SiS 7001 PCI-USB Open Host Controller Bus 0, Device 3, Function 3 SiS 7002 USB 2.0 Enhanced Host Controller Bus 0, Device 2, Function 7 SiS 7012 Audio Device Bus 0, Device 2, Function 5 SiS 85C513 IDE Controller Bus 0, Device 2, Function 0 SiS 964 PCI-ISA Bridge Bus 0, Device 1, Function 0 SiS AGP Controller PnP Devices: PNP0303 101/102-Key or MS Natural Keyboard PNP0501 16550A-compatible UART Serial Port PNP0501 16550A-compatible UART Serial Port PNP0C08 ACPI Driver/BIOS FIXEDBUTTON ACPI Fixed Feature Button THERMALZONE ACPI Thermal Zone PNP0200 DMA Controller PNP0401 ECP Parallel Port PNP0C0B Fan PNP0700 Floppy Disk Controller GENUINEINTEL_-_X86_FAMILY_15_MODEL_2 Intel(R) Pentium(R) 4 CPU 2.66GHz PNP0F13 Logitech PS/2 Port Mouse PNP0C02 Motherboard Resources PNP0C04 Numeric Data Processor PNP0800 PC Speaker PNP0A03 PCI Bus PNP0C0C Power Button PNP0000 Programmable Interrupt Controller PNP0B00 Real-Time Clock PNP0C0E Sleep Button PNP0C01 System Board Extension PNP0100 System Timer LPT PnP Devices: MICROSOFTRAWPORT Printer Port Logical Interface Ports: COM1 Communications Port (COM1) COM2 Communications Port (COM2) LPT1 ECP Printer Port (LPT1) --------[ Device Resources ]-------------------------------------------------------------------------------------------- DMA 02 Exclusive Standard floppy disk controller DMA 03 Exclusive ECP Printer Port (LPT1) DMA 04 Exclusive Direct memory access controller IRQ 00 Exclusive System timer IRQ 01 Exclusive Easy Internet Keyboard IRQ 03 Exclusive Communications Port (COM2) IRQ 04 Exclusive Communications Port (COM1) IRQ 06 Exclusive Standard floppy disk controller IRQ 08 Exclusive System CMOS/real time clock IRQ 09 Shared Microsoft ACPI-Compliant System IRQ 12 Exclusive Logitech-compatible Mouse PS/2 IRQ 13 Exclusive Numeric data processor IRQ 14 Exclusive Primary IDE Channel IRQ 15 Exclusive Secondary IDE Channel IRQ 16 Shared RADEON 9600 SERIES IRQ 18 Shared Realtek RTL8139 Family PCI Fast Ethernet NIC IRQ 18 Shared Realtek AC'97 Audio IRQ 20 Shared SiS 7001 PCI to USB Open Host Controller IRQ 21 Shared SiS 7001 PCI to USB Open Host Controller IRQ 22 Shared SiS 7001 PCI to USB Open Host Controller IRQ 23 Shared SiS PCI to USB Enhanced Host Controller Memory 00000000-0009FFFF Exclusive System board Memory 000A0000-000BFFFF Shared PCI bus Memory 000A0000-000BFFFF Shared RADEON 9600 SERIES Memory 000A0000-000BFFFF Undetermined SiS Accelerated Graphics Port Memory 000CD000-000CFFFF Exclusive System board Memory 000F0000-000F7FFF Exclusive System board Memory 000F8000-000FBFFF Exclusive System board Memory 000FC000-000FFFFF Exclusive System board Memory 00100000-3FFEFFFF Exclusive System board Memory 3FFF0000-3FFFFFFF Exclusive System board Memory 40000000-FEBFFFFF Shared PCI bus Memory C0000000-CFFFFFFF Exclusive RADEON 9600 SERIES Memory C0000000-DFFFFFFF Exclusive SiS Accelerated Graphics Port Memory D0000000-DFFFFFFF Exclusive RADEON 9600 SERIES - Secondary Memory E0000000-E7FFFFFF Exclusive SiS Accelerated Graphics Port Memory E8000000-E9FFFFFF Exclusive SiS Accelerated Graphics Port Memory E9000000-E900FFFF Exclusive RADEON 9600 SERIES Memory E9FF0000-E9FFFFFF Exclusive RADEON 9600 SERIES - Secondary Memory EA000000-EA000FFF Exclusive SiS 7001 PCI to USB Open Host Controller Memory EA001000-EA001FFF Exclusive SiS 7001 PCI to USB Open Host Controller Memory EA002000-EA002FFF Exclusive SiS 7001 PCI to USB Open Host Controller Memory EA003000-EA003FFF Exclusive SiS PCI to USB Enhanced Host Controller Memory EA004000-EA0040FF Exclusive Realtek RTL8139 Family PCI Fast Ethernet NIC Memory FEC00000-FECFFFFF Exclusive System board Memory FEE00000-FEEFFFFF Exclusive System board Memory FFEE0000-FFEFFFFF Exclusive System board Memory FFFE0000-FFFEFFFF Exclusive System board Memory FFFF0000-FFFFFFFF Exclusive System board Port 0000-000F Exclusive Direct memory access controller Port 0000-047F Shared PCI bus Port 0010-001F Exclusive Motherboard resources Port 0020-0021 Exclusive Programmable interrupt controller Port 0022-003F Exclusive Motherboard resources Port 0040-0043 Exclusive System timer Port 0044-005F Exclusive Motherboard resources Port 0060-0060 Exclusive Easy Internet Keyboard Port 0061-0061 Exclusive System speaker Port 0062-0063 Exclusive Motherboard resources Port 0064-0064 Exclusive Easy Internet Keyboard Port 0065-006F Exclusive Motherboard resources Port 0070-0073 Exclusive System CMOS/real time clock Port 0074-007F Exclusive Motherboard resources Port 0080-0090 Exclusive Direct memory access controller Port 0091-0093 Exclusive Motherboard resources Port 0094-009F Exclusive Direct memory access controller Port 00A0-00A1 Exclusive Programmable interrupt controller Port 00A2-00BF Exclusive Motherboard resources Port 00C0-00DF Exclusive Direct memory access controller Port 00E0-00EF Exclusive Motherboard resources Port 00F0-00FF Exclusive Numeric data processor Port 0170-0177 Exclusive Secondary IDE Channel Port 01F0-01F7 Exclusive Primary IDE Channel Port 0274-0277 Exclusive ISAPNP Read Data Port Port 0279-0279 Exclusive ISAPNP Read Data Port Port 0290-0297 Exclusive Motherboard resources Port 02F8-02FF Exclusive Communications Port (COM2) Port 0376-0376 Exclusive Secondary IDE Channel Port 0378-037F Exclusive ECP Printer Port (LPT1) Port 03B0-03BB Shared RADEON 9600 SERIES Port 03B0-03BB Undetermined SiS Accelerated Graphics Port Port 03C0-03DF Shared RADEON 9600 SERIES Port 03C0-03DF Undetermined SiS Accelerated Graphics Port Port 03F0-03F5 Exclusive Standard floppy disk controller Port 03F6-03F6 Exclusive Primary IDE Channel Port 03F7-03F7 Exclusive Standard floppy disk controller Port 03F8-03FF Exclusive Communications Port (COM1) Port 0490-0CF7 Shared PCI bus Port 04D0-04D1 Exclusive Motherboard resources Port 0778-077B Exclusive ECP Printer Port (LPT1) Port 0800-0805 Exclusive Motherboard resources Port 0A79-0A79 Exclusive ISAPNP Read Data Port Port 0D00-0FFF Shared PCI bus Port 1100-FFFF Shared PCI bus Port 4000-400F Exclusive SiS 5513 IDE UDMA Controller Port D000-D0FF Exclusive RADEON 9600 SERIES Port D000-DFFF Exclusive SiS Accelerated Graphics Port Port E000-E0FF Exclusive Realtek AC'97 Audio Port E400-E47F Exclusive Realtek AC'97 Audio Port E800-E8FF Exclusive Realtek RTL8139 Family PCI Fast Ethernet NIC --------[ Power Management ]-------------------------------------------------------------------------------------------- Power Management Properties: Current Power Source AC Line Battery Status No Battery Full Battery Lifetime Unknown Remaining Battery Lifetime Unknown --------[ Debug - PCI ]------------------------------------------------------------------------------------------------- B00 D00 F00: SiS 661FX Chipset - Host-PCI Bridge Offset 00: 39 10 61 06 07 00 10 22 11 00 00 06 00 20 80 00 Offset 10: 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 7B 14 06 18 Offset 30: 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 50: FF 09 01 83 43 03 0D 0D 03 25 08 00 12 DB 20 06 Offset 60: 6B 6B 6C 00 03 80 DA 82 01 10 E0 00 6A 00 80 00 Offset 70: 0F 9F 00 80 02 00 00 90 00 00 00 00 02 0F 00 44 Offset 80: 22 27 30 03 81 00 04 2B 00 00 00 01 00 00 00 40 Offset 90: 00 00 00 00 50 00 00 00 B0 80 2C 02 00 00 00 1B Offset A0: A5 A8 77 42 03 03 01 33 41 AA 40 00 44 01 00 04 Offset B0: 00 00 00 80 81 01 20 00 12 3C 30 30 00 00 30 00 Offset C0: 02 00 35 00 0B 4E 00 1F 02 03 00 00 00 00 00 00 Offset D0: E0 01 00 00 20 0F 01 00 00 00 10 00 00 00 00 88 Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset F0: 18 15 00 00 00 00 AA AA 00 00 00 00 00 00 00 00 B00 D01 F00: SiS AGP Controller Offset 00: 39 10 03 00 07 01 20 00 00 00 04 06 00 40 01 00 Offset 10: 00 00 00 00 00 00 00 00 00 01 01 20 D0 D0 20 20 Offset 20: 00 E8 F0 E9 00 C0 F0 DF 00 00 00 00 00 00 00 00 Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0E 00 Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset D0: 22 42 30 06 09 FF FF 01 60 60 AA 12 03 07 07 23 Offset E0: 23 47 15 A0 00 00 00 00 55 00 55 E5 00 00 00 00 Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D02 F00: SiS 964 PCI-ISA Bridge Offset 00: 39 10 64 09 0F 00 00 02 36 00 01 06 00 00 80 00 Offset 10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 40: 92 8A 80 8B 80 40 3D DD 10 00 00 00 11 30 04 01 Offset 50: 11 38 02 01 20 0B 20 00 FF FF 12 00 00 05 00 00 Offset 60: 8A 8B 89 85 FF C1 0C 12 09 80 00 46 B7 00 02 14 Offset 70: 00 00 FF FF 00 10 03 2C 20 00 20 80 16 00 00 00 Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 90: 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset C0: 01 00 00 40 00 00 00 00 0F 9F 00 00 00 00 00 41 Offset D0: 20 0D 00 01 22 26 30 00 81 00 04 2B AA AA AA AA Offset E0: 40 00 00 D8 7C 00 44 00 00 00 00 00 00 00 00 00 Offset F0: 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D02 F05: SiS 85C513 IDE Controller Offset 00: 39 10 13 55 05 00 10 02 01 8A 01 01 00 80 00 00 Offset 10: F1 01 00 00 F5 03 00 00 71 01 00 00 75 03 00 00 Offset 20: 01 40 00 00 00 00 00 00 00 00 00 00 7B 14 06 18 Offset 30: 00 00 00 00 58 00 00 00 00 00 00 00 00 01 00 00 Offset 40: 00 00 00 00 00 00 00 00 10 00 06 00 00 00 00 00 Offset 50: 9B A1 9A 21 2A 96 C5 D0 01 00 02 80 00 00 00 00 Offset 60: FB AA FB AA 00 00 00 00 81 00 00 81 00 00 00 00 Offset 70: 56 23 06 04 00 60 1C 1E 00 60 1C 1E 56 23 06 04 Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D02 F07: SiS 7012 Audio Device Offset 00: 39 10 12 70 05 00 90 02 A0 00 01 04 00 20 00 00 Offset 10: 01 E0 00 00 01 E4 00 00 00 00 00 00 00 00 00 00 Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 7B 14 06 18 Offset 30: 00 00 00 00 48 00 00 00 00 00 00 00 12 03 34 0B Offset 40: 04 00 00 00 00 00 00 00 01 00 42 C6 00 00 00 00 Offset 50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset F0: 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D03 F00: SiS 7001 PCI-USB Open Host Controller Offset 00: 39 10 01 70 07 00 80 02 0F 10 03 0C 08 20 80 00 Offset 10: 00 00 00 EA 00 00 00 00 00 00 00 00 00 00 00 00 Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 7B 14 06 18 Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 14 01 00 50 Offset 40: 00 00 00 00 5C AC 01 00 3F 02 00 00 00 00 00 00 Offset 50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 C2 C9 Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D03 F01: SiS 7001 PCI-USB Open Host Controller Offset 00: 39 10 01 70 07 00 80 02 0F 10 03 0C 08 20 00 00 Offset 10: 00 10 00 EA 00 00 00 00 00 00 00 00 00 00 00 00 Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 7B 14 06 18 Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 15 02 00 50 Offset 40: 00 00 00 00 5C AC 01 00 3F 02 00 00 00 00 00 00 Offset 50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 C2 C9 Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D03 F02: SiS 7001 PCI-USB Open Host Controller Offset 00: 39 10 01 70 07 00 80 02 0F 10 03 0C 08 20 00 00 Offset 10: 00 20 00 EA 00 00 00 00 00 00 00 00 00 00 00 00 Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 7B 14 06 18 Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 16 03 00 50 Offset 40: 00 00 00 00 5C AC 01 00 7F 02 00 00 00 00 00 00 Offset 50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 C2 C9 Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D03 F03: SiS 7002 USB 2.0 Enhanced Host Controller Offset 00: 39 10 02 70 06 00 90 02 00 20 03 0C 08 20 00 00 Offset 10: 00 30 00 EA 00 00 00 00 00 00 00 00 00 00 00 00 Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 7B 14 06 18 Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 17 04 00 50 Offset 40: 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 Offset 50: 01 00 C2 C9 00 00 00 00 0A 00 00 21 00 00 00 00 Offset 60: 20 20 FF 01 00 00 00 00 00 00 00 00 00 00 00 00 Offset 70: 01 00 00 00 00 00 00 C0 00 00 E7 3F 00 00 00 00 Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D0E F00: Realtek RTL8139 Fast Ethernet Adapter Offset 00: EC 10 39 81 05 00 90 02 10 00 00 02 00 20 00 00 Offset 10: 01 E8 00 00 00 40 00 EA 00 00 00 00 00 00 00 00 Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 7B 14 06 18 Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 12 01 20 40 Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 50: 01 00 C2 F7 00 01 00 00 00 00 00 00 00 00 00 00 Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B01 D00 F00: ATI Radeon 9600 (RV350) Video Adapter Offset 00: 02 10 50 41 07 00 B0 02 00 00 00 03 08 20 80 00 Offset 10: 08 00 00 C0 01 D0 00 00 00 00 00 E9 00 00 00 00 Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 02 10 50 41 Offset 30: 00 00 00 00 58 00 00 00 00 00 00 00 10 01 08 00 Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 02 10 50 41 Offset 50: 01 00 02 06 00 00 00 00 02 50 30 00 1B 02 00 FF Offset 60: 02 43 00 1F 00 00 00 00 00 00 00 00 00 00 00 00 Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 80: 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B01 D00 F01: ATI Radeon 9600 (RV350) - Secondary Video Adapter Offset 00: 02 10 70 41 07 00 B0 02 00 00 80 03 08 20 00 00 Offset 10: 08 00 00 D0 00 00 FF E9 00 00 00 00 00 00 00 00 Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 02 10 51 41 Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 08 00 Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 50: 01 00 02 06 00 00 00 00 02 50 30 00 1B 02 00 FF Offset 60: 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 --------[ Debug - Video BIOS ]------------------------------------------------------------------------------------------ C000:0000 U.h...........................IBM=.............. 761295520...... C000:0040 ??......$.......2004/01/15 11:26.....T..........DR(7....PA...... C000:0080 .. RADEON 9600LE SAMSUNG-E 400/203 PAL BIOS...(C) 1988-2003, ATI C000:00C0 Technologies Inc. BK-ATI VER008.015.058.000. pa400203.815 v611 C000:0100 .V350AGP DGD1UN..OEM VER.000.000..l.......l....Z................ C000:0140 ..PAPA.........x.n..^.'.S.A...$TVS3................K........... C000:0180 ................PCIR..PA........h.......ATI RADEON 9600 PRO..... C000:01C0 ................................................................ C000:0200 ............q.......Wxx......................................... C000:0240 ................................................................ C000:0280 ................................................0 ..3Q0`........ C000:02C0 ..OD..P ....P`........X ..........| ..........X`........hA..... C000:0300 [email protected].....=..x.0 ..|................... C000:0340 ........................ ...........+.......f..........`........ C000:0380 ..X:..........X:....!.....I............U...........U....&....... C000:03C0 ..../.....m.....%......."".......M.......[..u..`...............@ ------------------------------------------------------------------------------------------------------------------------ The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
Sorry to ask this but you didn't say whether you actually installed the drivers because I think you have generic XP drivers installed. You can download the ATI drivers here or you can try Omega drivers if you want.
Where do you get the message? When you see your desktop? I would follow addis' links if you can. You might wanna try going into your BIOS, go to integrated peripherals, disable onboard video, or set primary video to AGP.
