Vista problems...
Discussion in 'Windows OS's' started by Dambuster, Mar 20, 2007.
  1. Dambuster
    Dambuster Magic
    First of all, the HDD is working all the time and slowing the system down... then I get the blue screen of death (no idea why), and the firewall is off and I can't get it on and to make matters worse, there are all the time error messages saying failed this, broken that etc...
    Believe me since I had to buy a Windows I got Vista but if I had xp I'd have installed it without a doubt...
    Now my question is: do you know any maintenance tools (i.e. registry cleaner) for Vista? Also, does anyone know the cause of the constant HDD activity?
    Thanks for the help! ;)
  2. Dambuster
    Dambuster Magic
    All I'm asking for is a maintenance program like TuneUp utilities 2006 for Windows Vista, cause it's getting pretty buggish at the moment...
  3. Sniper
    Thats one of the drawbacks to taking up a new OS because not everything works as you expected...
    Anyway, how about [google]CCleaner[/google], it might help. Also checkout Windows Vista RTM Software Compatibility List - IeXwiki.
    You might have a antivirus software monitoring everything you do, which could cause constant HDD activity.
  4. Dambuster
    Dambuster Magic
    thanks a lot! yeah believe me, if I didn't have to, I wouldn't even use windows... I got Vista because I thought it's stupid to get XP when a newer OS is there...
    Tell me another thing please: Will there be any problem with installing XP PRO SP2 on 2 machines?
  5. thomas234
    thomas234 Big Geek
    If you have 2 licences for it, or a multi-user licence then no. Otherwise you may encounter problems with Windows Activation, unless it's a corporate edition which doesn't need activating.
  6. Dambuster
    Dambuster Magic
    oh crap... then I'll have to bear with Vista till the problems get fixed... :( :mad: :doh: I only have a XP PRO OEM... (SP2)
