It turns on for about 2 seconds then turns off. I changed the power supply because i thought that that was the problem and nothing. But if i leave my computer unplugged for couple of days it will turn on again. So what is my PROBLEM?? PLZ HELP
disconnect the power switch from the motherboards control panel and use a flat head screw driver to short the two power switch pins. could well be a jammed power button.
