Wireless performance
Discussion in 'Linux, BSD and Other OS's' started by sabashuali, Apr 5, 2010.
  1. sabashuali
    sabashuali Ani Ma'amin
    For one reason or another, I have got Windows running again on my laptop. Very long story but I am soon to go back to my preferred Debian.
    One thing I have noticed is that although the laptop is crawling again, the wireless performance is way, way better using windows.
    When using Debian, I use the ath5k driver by default, as in I did not have to do anything to get wireless working out of the box. However, speeds are normally about 25% to 30% lower, if not more and not very reliable. Set up is exactly the same but man, performance is much better under windows.... :x:
    Is anyone experiencing the same? Is there anyway of boosting wireless connection with ath5k?
    Ta, very moch for looking... :cool:
  2. Anti-Trend
    Anti-Trend Nonconformist Geek Staff Member
    I've got a similar chipset on my ATOM-based mini-ITX media center, which is running Debian Lenny and the ATOM kernel from the HWF repos. The wireless reception on that chipset is *sweet* in 2.6.32.xx. Which kernel are you running on your Deb box?
    EDIT: I take it back, it seems to be a more advanced chipset after all:
  3. sabashuali
    Hey AT. Thanks for responding.
    I was using Debian Testing running the latest HWF Kernel (as you already noted 2.6.32.xx).
    Perhaps I should look into getting a better chipped wifi card?
  4. Anti-Trend
    For a chipset of that age, you might try madwifi and see how it works for you.
  5. sabashuali
    Given... unfortunately, when I try to use the module-assistant it cannot get the source (madwifi was dropped in Lenny and onwards.... I think :x:). I know it sounds pathetically lame but this obviously means that I will need to build madwifi from source after getting the source outside the Dedian repositories... right?
  6. Anti-Trend
    Looks like it's in non-free:
    ...Or you could just download the latest source from madwifi.org and build it yourself. :) They do have rather good instructions on how to build and install it in Debian IIRC.
    http://madwifi-project.org/
  7. sabashuali
    Cool... Thanks AT. I will give it a go when I am back with the real stuff... :cool:
