Need Help Picking Psu
Discussion in 'Power Supplies and UPS's' started by Torinaj, Feb 17, 2017.
  1. Torinaj
    Torinaj Geek Trainee
    I am doing a DIY router using pfSense, and need to choose a PSU. These two seem to be the only ones that will fit my case, and have mostly good buyer reviews:
    Seasonic SS-300TFX
    Seasonic SS-300TGW
    Could use some help picking one. My case is Apex DM-317-A, for any curious.
  2. Wicked Mystic
    Wicked Mystic Big Geek
    I'd go with Seasonic SS-300TGW.
  3. Torinaj
    Someone on another forum said both Seasonic PSUs are too wide to fit the case. Can you doublecheck that?
  4. Wicked Mystic
    Current PSU dimensions: 5.75" x 3.25" x 2.5"
    Seasonic PSU dimensions: 6.9" x 3.3" x 2.5"
    So it is possible Seasonic is too big.
    Many "slim" type cases accept ATX PSU so getting new case may give much better PSU options.
    Torinaj likes this.
  5. Torinaj
    I agree. Time to ditch this case. Second choice is HEC Compucase 7K09BBA30FNRX. Haven't been able to track down size of its included PSU, so not sure if either will fit, but hoping for either Seasonic SS-300TFX or SS-300TGW...what do you think? My third choice for case is Apex MJ-16, but not liking its big size at all, so I would see it as last resort.
  6. Wicked Mystic
    For HEC, PSU is HEC-300W TFX
    85x175x65mm (3.3x6.9x2.5)
    Same size as Seasonic. So Seasonic should fit in that case.
    Torinaj likes this.
  7. Torinaj
    Excellent! HEC may not look as good as the other case, but it will do. Do you have any preference between the two Seasonic models? I could flip a coin, but would like to hear your thoughts. Once I pick the power supply my build will be complete (on paper). Could I impose on you to look it over, and check for incompatibilities or potential problems?
  8. Wicked Mystic
    My choice would be SS-300TGW.
    If you post your system here, I'll check it out.
    Torinaj likes this.
  9. Torinaj
    CASE: HEC Compucase 7K09BBA30FNRX
    CASE FANS: Noctua NF-R8-1800
    CPU: Intel core i3-4160
    CPU COOLER: Noctua NH-L9x65
    MOTHERBOARD: Gigabyte GA-B85M-DS3H-A
    RAM: Corsair Vengeance CML8GX3M2A1600C9
    SSD: Either Intel 530 or 535 series; 120GB (whichever I can find at bargain price)
    SSD BRACKET: Sabrent BK-HDDF
    NIC: Intel EXPI9402PT
    NIC LOW-PROFILE BRACKET: Intel E1G42ET
    DVD-ROM: Asus DVD-E818AAT/BLK/B/GE
    PSU: Seasonic SS-300TFX Bronze or Seasonic SS-300TGW*
    MISC: IOgear 2-port KVM #GCS72U
    * I am hoping I can get the SS-300TFX to fit, but if you tell me it will not work, then SS-300TGW is the second choice.
  10. Wicked Mystic
    i3-4160 is old LGA1150 socket so I either recommend waiting for Ryzen 3 or getting Intel LGA1151.
  11. Torinaj
    That would not fit the motherboard, so far as I know. So is everything on my parts-list compatible?
  12. Wicked Mystic
    You'll need different motherboard yes. I cannot recommend LGA1150 as it's so old already and motherboard availability will be problem in the future.
    Other than that system looks basically OK. Not sure if CPU cooler is small enough to fit case though.
    Torinaj likes this.
