I recently tried to install a new power supply, only to find that after installing it, the power switch did not do anything. Nothing turned on at all. I put the new power supply back in, and still nothing happened. I am not sure what could be wrong. Any help is appreciated.
Hmm, you may be getting a short somewhere if a metal object got trapped between the motherboard and the panel.
The old PSU no longer seems to work, so it seems I have either damaged something, thrown a switch the wrong way, am forgetting to make a connection or am shorting something. However, I checked the mobo for any connecting metal objects and didnt find any. Im not sure what I could have damaged to cause this type of problem.
If the old one worked I was gonna tell you to double check to see if it was set to 110v or 230v on the back.
