1920x1200 Monitor - Recommendation
Hi,
I want to buy a monitor that will mostly be used for Web Development (and maybe a little bit of Graphic Design). The resolution that I want is 1920x1200.
I found some good offers for the following models:
AOC P2460PXQU
AOC i2460Pxqu
Philips 240P4QPYEB
Benq BL2411PT
Also, I found a few from Asus:
Asus PB248Q, Asus PA248Q, Asus VS24AHL and one from Dell: Dell U2412M
Now, my question is specially about the brand (how much it can be trusted) and also about the ease of use. I would prefer it to not require calibration. That’s why I would avoid buying a Dell (even though AOC also requires some calibration). And I would avoid Asus, too; I had an experience with a PB248Q, which, because of the rotating feature, didn’t stand at exactly 0 degrees (it went a bit more to the left).
I know that all these brands don’t produce their own monitors (and this usually results in a need for calibration or other configurations), but I am not sure about Benq (?).
Which one would you recommend me?
Thank you!
I have Benq BL2411PT, excellent image quality. Missing USB hub and height should be more adjustable. Also only 60Hz. Still very good monitor and much better than any 16:9 crap.
