Hi there, everyone. Hope you lads can help me with a problem I’ve got, but as I’m not very tech-minded as far as PC’s are concerned, you’ll have to keep all instructions/jargon simple, please (at least until I know what I’m doing, lol) I reckon it’s probably best to think you’re talking to a 10 year-old, lol!
My rig’s specs:
Windows XP Home Edition + SP 2
AsRock K7S8X (v3.0) with 1Gb DDR (2x 512Mb)
Athlon XP 2800+ CPU @2.25GHz
ATI Radeon 9800 Pro (OEM) 256Mb/256-Bit with Arctic Cooler
120GB HDD
16x DVD-ROM drive
52x CD-RW drive
Floppy Drive
3x case fans
My problem concerns the AGP data rate setting. As you know, the Radeon 9800 Pro is 4x/8x compatible, as is my (crappy?) AsRock mainboard. However, when I go to Catalyst Control Centre >SMARTGART, it says the AGP speed is set to ‘OFF’. I’ve tried setting it to both 4x and 8x speed but it won’t accept any changes upon rebooting. I ran Sandra 2004 to double check and, under ‘Mainboard Info’, it says: ‘AGP bus is unused or AGP card is not fully compatible’ as well as: ‘Current AGP data rate not optimal’.
Having checked the system’s BIOS, I was left more than a bit puzzled because under ‘Resource Configuration’ it clearly states:
Primary Graphics Adapter: ‘AGP’
AGP Data Rate: ‘8x’
AGP Fast Write: ‘Enabled’.
To make one further, final check, I reinstalled my old GeForce 4 Mx440 128Mb card but it wasn’t recognised as running at APG 8x speed either (though I’m pretty sure it used to…?)
Both Doom 3 and Half-Life 2 run pretty well on my ATI card, but I occasionally get slowdown when there’s a lot going on on-screen (it was this that made me check out the AGP settings in the first place).
If it’s of any help, the mainboard’s BIOS is the original flash. However, I’ve just updated Catalyst Control Centre to the new 5.1 release (was running 4.12 previously).
So, got any ideas, fellahs? Is my mainboard (or specifically the AGP slot) knackered for some reason? If so, can you recommend a half-decent replacement that’s not overly expensive? Or have I just missed something very obvious…like Win XP’s Service Pack 2 messing things up for me? (Only kidding, lol!) As I said, I’m no tech-head, so I’d appreciate your advice, but please keep it simple, lol… ![]()
Many thanks in advance…
