Annoying noise leak on headset
So I have a Plantronics 626 .DPS headset, and at ridiculously low volume, it noise leaks. By low volume, I mean anything under 5/100. This only started happening after I plugged it in to a different USB slot. Before then in the other slot it was not like this. Is there any way I can reset the driver or something, I tried plugging it into the other USB slot but no success.
P.S. Don’t know if this is the right board, new here
