is there anyone up to the challage of making a really gd singniture including gir from invader zim, if anyones ever heard of it. i have noticed that there is a pole going between two sigs and i recently had a look at mine and it is one of the worst ones ive ever seen. ive heard from a friend that they had theres done by someone on here and i was looking for some help. so if you think you can lend a hand id really appreciate any and all help.
thanks
And this is coming from a person who only goes in the arcade! Shame on you.
Don’t count on it but Waffles done sigs before and I can do some very basic ones but I don’t know aobut any other members.
ok well i cant help if that the arcade is one the things i like to do, im not used to posting anyways, not yet atleast. so you said you can make a very basic one for, well why dont you make it and ill tell you what i think, at this point anything will be better then the one ive got at the moment.
Ok, i’ll start with it and see what I end up with.
sounds good to me
thanks
I’ll make you one if addis can’t be assed, but on the condition that you participate a little more in the forums ![]()
hay thanks, that is one of the main reasons for me wanting one, i feel that it i just wrong to go jut to the arcade so im going to spend more time in the forums
I was gunna call u a lazy :swear: and tell u to make u own and then i thort …Waffles made mine. I can make em just not as good as waffles but coz he made mine i cant complain about you…damn
well there you go i dont have the Software anyway, i would make mine otherwise
Would u like photoshop…i’ll ‘buy’ it for u if u want
yea sure if you can be assed for once
Ill see if i can aquire it
that would be great, that way im not looked at a being lazy
Ill give it a try , sorry i was gone for a while, my computer was having problems and we are in the middle of a moving.
hey no problem take your time, im in no rush
Well nics not obliged to buy you one. not having the software is no excuse. more like no basic proficiency. You can download [google]GIMP 2[/google] which is a free but quite powerful software with features found in a lot of really expensive professional toolslike photoshop.
ok thanks, i might just do that
not too much work involved, but hope you like it… didnt tell what name you wanted on it, so i put that, if you want it changed just ask : D also i didnt make a avatar with it sry im lazy XD
nice work Opeio!
You probably need to find a new image host, though. Whoever you’re linking off of doesn’t seem to like being an image host.
