Hi all,
I am new to ASP.NET, but I have a question. I am having trouble with form tags. I know there can only be one form tag per page, but that won’t let me do what I want to do.
I have a calendar at the top of the page (ASP.NET framework) nested in a form tag.
At the bottom of the page, I want a button that submits some user data. The two are entirely unrelated, but I can’t figure out how to get both on the same page. Thanks for any help.
You can have multiple HTML form objects in a HTML document.
Yeah, I know. I can get that to work, but on ASP.NET, it only allows one form. I solved this though, by making the whole page one form. Thanks for your reply.
aspnettutorials.com
dotnettutorials.com
123asxp.com
411asp.com
All good references and snippet sites for you. ENoy!
Thank you everyone for the replies. I found out what I did just a minute ago. For anyone wondering, you place the form tags around the entire page. I didn’t realize that was what you needed to do, but once I did it, the whole page worked like a charm.
Thanks again.
[SOLVED]
