i was wondering if anyone know what the best broadband provider out of UK Online, Telewest, or Toucan. i am looking for the best 2mg unlimited broadband. thanks
I would reccomend that you read this: http://www.moneysavingexpert.com/cgi-bin/viewnews.cgi?newsid1092034925,22928 ,
(its also worth signing up to the mailing list on that site!)
Telewest hands down. Their speeds are consistent, compared to other ISPs offering the same speed connections are slightly faster with Blueyonder. I’ve used it in the past and no problems. But then again, the comparison wasn’t between all ISPs.
I found this the best comparison site - http://www.adslguide.org.uk/
All reviews are by customers. You can also test your speed although it is not very accurate.
This is how I found my current ISP which I am very happy with.
Good luck.
The internet connection at my flat is provided by BlueYonder. Sometimes it’s lightning fast, and at other times its as slow as dialup ![]()
