I have a Lite-On SOHW-1693S which I only bought the other day.
Been mainly using it for burning DVDs… did the odd CD.
Did a CD tonight and it revved up (noisy little thing at 48x) like it did the other times but at 50%, the sound revved all the way down. Then nothing, then like a cracking sound.
Only way I could abort program/get CD out was a restart.
Went back into Nero.
Now it can’t detect if a CD is blank. If I create a list of things to burn, the drive makes a sound like a car revving up (low to high to low to high, etc) then stops accompanied with the message “no really… I said a BLANK disc” (you get what I mean)… ![]()
Not too worried as I’ll just ask for an identical exchange at shop if its bust, but not very happy at all about the fact that a brand new, supposedly reasonable DVD burner can actually f**k itself up whilst trying to burn a disc, and it could happen again.
Any ideas? Restarting doesn’t do the trick. If I re-installed the firmware do you think that would?
[SIZE=2][FONT=Century Gothic]UPDATE: Re-flashed firmware. No difference. Power off for two minutes. No difference. Can play discs that are written to, CD and DVD, but cannot detect a blank CD (and I can’t test that on DVD as I’m out of blank DVDs)[/FONT][/SIZE]
And after reading this thread I’m scared:
http://club.cdfreaks.com/showthread.php?t=78047
Shall I try reinstalling IDE drivers then, or the driver disc for the specific burner.
Is this a hardware, firmware or software problem??
Help urgently appreciated!!!
