Contact us any time on Lexmark Printers Tech Support Number +1-866-877-0191.
Just imagine, you make a report sheet on word or excel and you have urgent requirement to submit it and in that important time your Lexmark start to showing, no paper meanwhile the paper tray is almost full with papers, at this point you might be thinking to throw out printer in to dustbin but it’s not needed, all that requires is to care a little of your Lexmark printer. Errors take place if you don’t pay attention until it not stops working, there is a need to clear blockage and reduce dust time to time in the hardware of your printing device, It may too a cause of printer not performing well. We are finding some very common issues which exist with Lexmark and we provide technical support for them.
[ul]
[li]If a user can’t install drivers for Mac & windows[/li][li]Lexmark keeps restarting[/li][li]It’s not printing[/li][li]Keeps saying out of paper[/li][li]Printing blank/black[/li][li]Keeps jamming[/li][li]Not connected to internet[/li][li]Not connected to Wi-Fi[/li][li]No sync between printer and PC[/li][/ul]
Issues may exist with your Lexmark too Like Other Brand of Printers. Sometime printer does not print, error during installation and un-installation of printer drivers, printer goes offline, it’s loosing connection, saying out of paper, indicating right cartridge incorrect, if not working with any type of operating system (windows XP, windows 7, windows 8 etc.), keeps restarting, problem in wireless setup, print ratio is very slow and so on. You may Contact us on [B]Lexmark Printer Phone Number [/B]is +1-866-877-0191.
