Cooling Help
Hi Guys
I’m planning to aftermarket cooler into my build as was hoping someone could give me some advice.
At present I have an Intel i7 300k processor, Asus P8Z68-V PRO/GEN3 Motherboard, and 4 Corsair 8GB 1600MHz CL9 DDR3 Vengeance Memory modules.
I was thinking of getting the Cooler Master Hyper 212 EVO, but am concerned that it wont fit on to the motherboards due to space restrictions, i.e. memory getting the way.
Has anyone got any recommendations on what I can do?
Thanks Guys
This is what I am using :
http://www.arctic.ac/en/p/cooling/cpu/3/freezer-13.html
What do you mean by space Restrictions ???
This is mine Deep Cool Ice Blade Pro v2
I had to move my Corsair Vengeance 8gb kit Dual Channel 1600mhz cl9 to slots 2 and 4 since the cpu cooler has kinda small room for ram heatsinks.
Read the product dimensions and get the difference between total height/length - height/length of fins then you’ll get the dimension of the space in the ram part.
If your not budget restricted buy a water cool cpu cooler. Like this Antec KUHLER H2O 620 CPU Cooler.
