ok, my pc keeps crashing during games, usually after a couple of minutes. i have the latest drivers and i even got the graphics card i had replaced. (i had two months of no problems before all of this)
I replaced the motherboard just before all of this started happening and ive tried two different motherboards since.
So the motherboard, graphics card and its drivers are all not the problem. Which leads me to suspect that the processor could be overheating and cutting out to stop it from being damaged.
is this a possibility, since i had to take the processor out etc. maybe the thermopaste stuff is not making a good enough connection between the processor and the heatsink.
Doh, forgot to read all your system specs. Is it in all games your having problems or just a few. I’m thinking now it might be a problem with the 9700 if it’s just certain titles that are crashing.
Bad PSU…maybe. It could also be that it’s simply not enough. Have you picked the unit up by itself? If it was lite, it’s probably a cheaper model and has less components in it. Also, what does it say is the maximum wattage between the 3.3V and 5V rails—it should say on the PSU sticker.
The CPU will get hotter—how much depends on the CPU cooler. The stock P4 cooler is quite good, and the way they’re designed, I’m not seeing how it could really be installed improperly.
Also, if you’ve switched motherboards using different chipsets without a reinstall of Windows, that could be giving you headaches as well
