Ok all first post here, I hope you guys can help me!
I recently built my first system.
[COLOR=“Blue”]Core i7 920
CORSAIR CMPSU-750TX 750W ATX12V
ASUS P6T Deluxe LGA 1366 Intel X58 ATX (non OC - BIOS on default except for boot drives..)
CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
Monsoon III LT cooler with Arctic Silver V paste
SAPPHIRE 100245L Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16
Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM x2
Fujitsu MBA3073RC 73.5GB 15000 RPM Serial Attached SCSI (SAS) x1
built in an Antec P182
I KNOW I built it right, I did it very slowly. It started up, I installed Vista64 , Installed the drivers. Everything was running great. Say for about a day. The CPU temp was showing about 33 centigrade on idle, according to the ASUS utility.
OK, I next tried to to run Prime95. Not the torture test, just the basic program. No OC at all yet. Everything baseline.
I started the program and I looked at the temp and it said about 60. This after about 5-10 secs. Ok. About 2 secs later I heard some not good sounds from the case, a burning smell and before I could do anything - it shut down. I couldn’t restart. There was a clear burning smell. ![]()
I took the thing apart.
There was NO smell AT ALL from the PSU. Nada.
The paste seems to have been enough and spread around nicely.
The chip did not smell at all, even after I lifted it up and smelled it real close.
The only place that had a faint smell, was on the mobo.
I did not spot any obvious melty places.
So, I replaced the mobo under RMA.
[COLOR=“Red”]Alas, still does not work, so it was not the mobo. ![]()
This is what happens:
I connect the PSU and the onboard power button lights up.
I hit the ‘on’ button and I get about a half second startup - the CPU fan spins a bit and then the whole thing turns off and stops within about a half a sec. (Just as before I changed it)
[COLOR=“Green”]I then tried the following:
Removed vid card. Same. (so it not the card)
Put in a different PSU - same exact thing. (Only connected the fans and mobo, did not even connect any drives to the PSU) So it’s likely not the PSU or the drives.
I ask what could be causing it not to turn on at all and try to even POST? I guess it must be the CPU, no? I was so sure it was the mobo, darn it. Could I have fried both the motherboard AND the CPU in 10 secs?? I do not have another X58 system to check the CPU on or take another CPU to try on this system.
Will Newegg (USA. I know this is a UK based forum) let me send in another RMA for the CPU? What do I say?? Just nothing and say it won’t work? It LOOKS just fine - no burning and no obvious physical damage.
help!!!
