Crossfire 6870's - Power Requirements.
PC Specs:
Motherboard - Gigabyte HA65M-D2H-B3.
Memory - Corsair Vengeance DDR3 8GB Ram @ 1333Mhz.
Processor - Intel Sandy Bridge i5-2500K.
Power Supply - CIT 650W Black Edition.
HDDs - 1x Western Digital 500GB Sata III @ 6.0Gb/s, 1x Hitachi 500GB External HDD.
Cooling - Akasa Venom CPU Cooler, Akasa 12cm Viper Case Fan, Akasa 8cm Case Fan.
GPU - XFX 6870 1GB GDDR5.
I have just purchased a second 6870 and a new motherboard that will allow crossfire, an overclocked processor (with ease) and 1600Mhz RAM. This motherboard is an ‘MSI 14155 Intel P687 ATX Motherboard’. Now, here’s the question, would my 650W supply enough power to firstly run all of my components (mainly the crossfire), and overclocked proccessor (to between 4.0Ghz-4.5Ghz from 3.3Ghz) and 1600Mhz RAM or will I need an upgrade?
You should be ok, you might have a bit of a bottle neck though.
I found a PSU calculator by ASUS and it said I would need a 950W PSU :/. Now that would screw me over 'cos that’s another £110. Does this seem likely or should I go for like an 800W PSU to avoid bottlenecking, as they’re considerably cheaper.
No way you would not need 950W, I’d say if you wanted to avoid the bottleneck and be prepared for future upgrades I would get a(n) 8000W PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16817121069
Right, I live in the UK so I’ll have a look for another Crossfire ready PSU. Would I need the two PCIE 6pin connector or just the one?
[EDIT] Would this do? http://www.cclonline.com/product/42160/PC-850AUBA-M/Power-Supplies/850W-Powercool-High-Efficiency-Power-Supply/PSU1190/
That one is good, it will do just fine!
